[postgis-users] ST_Quantile
Joan
wamaithajoan at gmail.com
Fri Jan 27 11:42:15 PST 2012
The 0.75 is the quantile.
I will report the bugs. Thanks for the help/info.
Joan
On 27 January 2012 20:31, Stephen Woodbridge <woodbri at swoodbridge.com>wrote:
> Joan,
> Looking at the function the Bborie posted:
> st_quantile(rastertable text, rastercolumn text, nband int DEFAULT
> 1, exclude_nodata_value boolean DEFAULT TRUE, quantiles double
> precision[] DEFAULT NULL)
> The 3rd parameter is the band number. What is the 0.75 supposed to
> represent? My guess is that is getting truncated to 0 and it is trying to
> process band=0 which might not be valid.
> But it should not crash, so please write two bugs against this:
> 1. for the missing doc
> 2. for the crash if you enter 0.75
> Thanks,
> -Steve
> On 1/27/2012 2:19 PM, Joan wrote:
>> Hi Steve,
>> I have gotten the same problem (db server stopped running).
>> Joan
>> On 27 January 2012 20:05, Stephen Woodbridge <woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.**com <woodbri at swoodbridge.com>>> wrote:
>> Joan,
>> I've never used these function, but try doing:
>> select st_quantile('kbd_ext', 'rast', 0.75);
>> Since you probably do not want this called once for every row in the
>> table.
>> -Steve
>> On 1/27/2012 2:03 PM, Joan wrote:
>> Hi Bborie,
>> This is my query and it crashes the db server.
>> select st_quantile('kbd_ext', 'rast', 0.75) from kbd_ext limit 10;
>> Joan
>> On 27 January 2012 19:14, Bborie Park <bkpark at ucdavis.edu
>> <mailto:bkpark at ucdavis.edu>
>> <mailto:bkpark at ucdavis.edu <mailto:bkpark at ucdavis.edu>>> wrote:
>> Hey Joan,
>> Assuming your whole coverage is in a table, you should use the
>> table/column version of ST_Quantile (which by the looks of it
>> is
>> undocumented for some reason).
>> The function definition of ST_Quantile(rastertable,
>> rastercolumn) is...
>> DEFAULT
>> At the moment an aggregate version of ST_Quantile (and the
>> other
>> basic stats functions) does not exist. It is expected that
>> one will
>> be written for PostGIS 2.1 assuming dev-time is available.
>> -bborie
>> On 01/27/2012 09:06 AM, Joan wrote:
>> Hi,
>> I would like to find the quantile values of a whole raster
>> coverage, but
>> ST_Quantile returns quantile values of each tile. Which
>> would be
>> the best
>> method to approximate the quantile value of the whole
>> coverage?
>> Regards,
>> Joan
>> ______________________________ _________________
>> postgis-users mailing list
>> postgis-users at postgis. refractions.net
>> <http://refractions.net>
>> <mailto:postgis-users at postgis. refractions.net
>> <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> http://postgis.refractions. net/mailman/listinfo/postgis- users
>> <http://postgis.refractions. net/mailman/listinfo/postgis- users
>> <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>> Bborie Park
>> Programmer
>> Center for Vectorborne Diseases
>> UC Davis
>> 530-752-8380
>> postgis-users at postgis. refractions.net <http://refractions.net
>> ______________________________**_________________
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120127/f8244acd/attachment.html>
