[postgis-users] ST_Quantile
Bborie Park
bkpark at ucdavis.edu
Fri Jan 27 13:07:12 PST 2012
Joan,
I've committed a fix for that problem in r8949.
-bborie
On 01/27/2012 11:52 AM, Bborie Park wrote:
> The way you called ST_Quantile is perfectly acceptable as there are
> variants of ST_Quantile that support that form.
> I'm fixing the problem now and should have it committed later today.
> -bborie
> On 01/27/2012 11:42 AM, Joan wrote:
>> The 0.75 is the quantile.
>> I will report the bugs. Thanks for the help/info.
>> Joan
>> On 27 January 2012 20:31, Stephen
>> Woodbridge<woodbri at swoodbridge.com>wrote:
>>> Joan,
>>> Looking at the function the Bborie posted:
>>> st_quantile(rastertable text, rastercolumn text, nband int DEFAULT
>>> 1, exclude_nodata_value boolean DEFAULT TRUE, quantiles double
>>> precision[] DEFAULT NULL)
>>> The 3rd parameter is the band number. What is the 0.75 supposed to
>>> represent? My guess is that is getting truncated to 0 and it is
>>> trying to
>>> process band=0 which might not be valid.
>>> But it should not crash, so please write two bugs against this:
>>> 1. for the missing doc
>>> 2. for the crash if you enter 0.75
>>> Thanks,
>>> -Steve
>>> On 1/27/2012 2:19 PM, Joan wrote:
>>>> Hi Steve,
>>>> I have gotten the same problem (db server stopped running).
>>>> Joan
>>>> On 27 January 2012 20:05, Stephen Woodbridge<woodbri at swoodbridge.com
>>>> <mailto:woodbri at swoodbridge.**com<woodbri at swoodbridge.com>>> wrote:
>>>> Joan,
>>>> I've never used these function, but try doing:
>>>> select st_quantile('kbd_ext', 'rast', 0.75);
>>>> Since you probably do not want this called once for every row in the
>>>> table.
>>>> -Steve
>>>> On 1/27/2012 2:03 PM, Joan wrote:
>>>> Hi Bborie,
>>>> This is my query and it crashes the db server.
>>>> select st_quantile('kbd_ext', 'rast', 0.75) from kbd_ext limit 10;
>>>> Joan
>>>> On 27 January 2012 19:14, Bborie Park<bkpark at ucdavis.edu
>>>> <mailto:bkpark at ucdavis.edu>
>>>> <mailto:bkpark at ucdavis.edu<mailto:bkpark at ucdavis.edu>>> wrote:
>>>> Hey Joan,
>>>> Assuming your whole coverage is in a table, you should use the
>>>> table/column version of ST_Quantile (which by the looks of it
>>>> is
>>>> undocumented for some reason).
>>>> The function definition of ST_Quantile(rastertable,
>>>> rastercolumn) is...
>>>> DEFAULT
>>>> At the moment an aggregate version of ST_Quantile (and the
>>>> other
>>>> basic stats functions) does not exist. It is expected that
>>>> one will
>>>> be written for PostGIS 2.1 assuming dev-time is available.
>>>> -bborie
>>>> On 01/27/2012 09:06 AM, Joan wrote:
>>>> Hi,
>>>> I would like to find the quantile values of a whole raster
>>>> coverage, but
>>>> ST_Quantile returns quantile values of each tile. Which
>>>> would be
>>>> the best
>>>> method to approximate the quantile value of the whole
>>>> coverage?
>>>> Regards,
>>>> Joan
>>>> ______________________________ _________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis. refractions.net
>>>> <http://refractions.net>
>>>> <mailto:postgis-users at postgis. refractions.net
>>>> <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>>>> http://postgis.refractions. net/mailman/listinfo/postgis- users
>>>> <http://postgis.refractions. net/mailman/listinfo/postgis- users
>>>> <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>>>> Bborie Park
>>>> Programmer
>>>> Center for Vectorborne Diseases
>>>> UC Davis
>>>> 530-752-8380
>>>> postgis-users at postgis. refractions.net<http://refractions.net
>>>> ______________________________**_________________
Bborie Park
Programmer
UC Davis
530-752-8380
