[postgis-users] Make Check fails
Andreas Forø Tollefsen
andreasft at gmail.com
Tue Jan 31 07:12:31 PST 2012
2012/1/31 Mathieu Basille <basille at ase-research.org>
> Le 31/01/2012 09:51, Andreas Forø Tollefsen a écrit :
>> Hi Mathieu,
>> Thanks. I was thinking the same. I downloaded the latest from trunk.
>> ./autogen.sh
>> ./configure --with-raster --with-gui
>> Also tried --with-geosconfig and --with-gdalconfig manually with the same
>> problem.
>> Could it be worth a try to delete the postgis-2.0.so
>> <http://postgis-2.0.so> file and reinstall postgis?
> I don't think it is related to postgis-2.0.so, but really to the mess
> with GEOS installs. Try to make sure that you're using the correct
> geos-config. If you're using a Linux OS, you can try:
> sudo updatedb
> locate geos-config
> See how many do you have. Mine (compiled by myself) is in
> '/usr/local/bin/geos-config'. You can check if it is the correct one with,
> e.g. less:
> less /usr/local/bin/geos-config
> It shows me somewhere that this is the 3.4.0dev version:
> --version)
> echo 3.4.0dev
> Then I can use:
> ./configure --with-raster --with-geosconfig=/usr/local/**bin/geos-config
> Now you have to adjust it for your needs. How did you install GEOS 3.3.2?
> Did you use a package manager, or compile it manually? Only this will tell
> you which geos-config to use...
> Mathieu.
> Hi Mathieu,
I have compiled my geos myself using ./autogen.sh, ./configure, make, make
install.
Then i set the path to the geos-config manually when configuring postgis:
./configure --with-geosconfig=/usr/local/bin/geos-config --with raster
I also tried by reinstalling the latest geos3.4.dev from trunk.
However. I get the same error:
---- Making check in liblwgeom
make[1]: Entering directory
`/home/andreas/Downloads/postgis-2.0.0alpha3SVN/liblwgeom'
make -C cunit check
make[2]: Entering directory
`/home/andreas/Downloads/postgis-2.0.0alpha3SVN/liblwgeom/cunit'
/bin/bash ../../libtool --mode=link gcc -g -O2 -Wall -Wmissing-prototypes
-I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -o cu_tester cu_algorithm.o
cu_print.o cu_misc.o cu_ptarray.o cu_geodetic.o cu_geos.o cu_measures.o
cu_node.o cu_libgeom.o cu_split.o cu_surface.o cu_homogenize.o cu_out_wkt.o
cu_out_wkb.o cu_out_gml.o cu_out_kml.o cu_out_geojson.o cu_out_svg.o
cu_out_x3d.o cu_in_wkb.o cu_in_wkt.o cu_tester.o ../liblwgeom.la -lcunit
libtool: link: gcc -g -O2 -Wall -Wmissing-prototypes -I/usr/local/include
-DPOSTGIS_GEOS_VERSION=34 -o .libs/cu_tester cu_algorithm.o cu_print.o
cu_misc.o cu_ptarray.o cu_geodetic.o cu_geos.o cu_measures.o cu_node.o
cu_out_x3d.o cu_in_wkb.o cu_in_wkt.o cu_tester.o ../.libs/liblwgeom.so
/usr/lib/libcunit.so
#gcc -o cu_tester cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o
cu_geodetic.o cu_geos.o cu_measures.o cu_node.o cu_libgeom.o cu_split.o
cu_surface.o cu_homogenize.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o
cu_out_kml.o cu_out_geojson.o cu_out_svg.o cu_out_x3d.o cu_in_wkb.o
cu_in_wkt.o cu_tester.o ../.libs/liblwgeom.a -lm -lcunit -L/usr/local/lib
-lgeos_c
/home/andreas/Downloads/postgis-2.0.0alpha3SVN/liblwgeom/cunit/.libs/lt-cu_tester:
error while loading shared libraries: libgeos-3.4.0dev.so: cannot open
shared object file: No such file or directory
make[2]: *** [check] Error 127
make[2]: Leaving directory
make[1]: *** [check] Error 2
make[1]: Leaving directory
make: *** [check] Error 1
> Andreas
>> <mailto:basille at ase-research.**org <basille at ase-research.org>>>
>> It seems indeed to be related to your previous GEOS install. What
>> command did you use to compile PostGIS? Is it possible that the path to
>> geos-config is still linking to the previous install? You can override
>> it by: '--with-geosconfig=/usr/bin/__**geos-config' (or the one
>> related
>> to your current install of GEOS) in the ./configure.
>> Hope it helps. If not, please provide more details (OS, previous
>> commands, etc.).
>> Mathieu.
>> Le 31/01/2012 09:33, Andreas Forø Tollefsen a écrit :
>> Hi,
>> I have installed GEOS 3.3.2 and GDAL 1.9.
>> I previously had a GEOS SVN 3.4 installed, but no longer.
>> Still i get this error when running make check.
>> Any idea?
>> /home/andreas/Downloads/__**postgis-2.0.0alpha3SVN/__**
>> liblwgeom/cunit/.libs/lt-cu___**testr:
>> <http://libgeos-3.4.0dev.so>
>> <http://libgeos-3.4.0dev.so>: cannot open shared object file: No
>> such file
>> or directory
>> `/home/andreas/Downloads/__**postgis-2.0.0alpha3SVN/__**
>> liblwgeom/cunit'
>> `/home/andreas/Downloads/__**postgis-2.0.0alpha3SVN/__**liblwgeom'
>> ______________________________**___________________
>> postgis-users mailing list
>> postgis-users at postgis.__refrac**tions.net <http://refractions.net>
>> <mailto:postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
>> http://postgis.refractions.__**net/mailman/listinfo/postgis-_**
>> _users
>> <http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
>> ~$ whoami
>> Mathieu Basille, Post-Doc
>> ~$ locate
>> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
>> + Centre d'Étude de la Forêt
>> Département de Biologie
>> Université Laval, Québec
>> ~$ info
>> http://ase-research.org/__**basille<http://ase-research.org/__basille><
>> http://ase-research.org/**basille <http://ase-research.org/basille>>
>> ~$ fortune
>> ``If you can't win by reason, go for volume.''
>> Calvin, by Bill Watterson.
>> http://postgis.refractions.__**net/mailman/listinfo/postgis-_**_users
> ~$ whoami
> ~$ locate
> ~$ info
> ~$ fortune
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120131/77550025/attachment.html>
