[postgis-users] Make Check fails
Mathieu Basille
basille at ase-research.org
Tue Jan 31 07:23:46 PST 2012
Arf, I was just too late :)
I remember a similar problem with GDAL (also compiled manually), for which
the lib .so could not be found. You can first check the paths:
/sbin/ldconfig -p | grep geos
I have something like that:
libgeos_c.so.1 (libc6) => /usr/local/lib/libgeos_c.so.1
libgeos_c.so (libc6) => /usr/local/lib/libgeos_c.so
libgeos-3.4.0dev.so (libc6) => /usr/local/lib/libgeos-3.4.0dev.so
If you don't have this, you can try (use sudo if needed):
echo '/usr/local/lib' >> /etc/ld.so.conf
ldconfig
And check again. This should be enough for PostGIS to compile (at least it
worked for me).
Hope this helps,
Mathieu.
Le 31/01/2012 10:16, Andreas Forø Tollefsen a écrit :
> And the file exists:
> andreas at andreas-priogrid:~/Downloads/postgis-2.0.0alpha3SVN$ locate
> libgeos-3.4.0dev.so <http://libgeos-3.4.0dev.so>
> /home/andreas/Downloads/geos-svn/src/.libs/libgeos-3.4.0dev.so
> /usr/local/lib/libgeos-3.4.0dev.so <http://libgeos-3.4.0dev.so>
> 2012/1/31 Andreas Forø Tollefsen <andreasft at gmail.com
> <mailto:andreasft at gmail.com>>
> 2012/1/31 Mathieu Basille <basille at ase-research.org
> <mailto:basille at ase-research.org>>
> Le 31/01/2012 09:51, Andreas Forø Tollefsen a écrit :
> Hi Mathieu,
> Thanks. I was thinking the same. I downloaded the latest from
> trunk.
> ./autogen.sh
> ./configure --with-raster --with-gui
> Also tried --with-geosconfig and --with-gdalconfig manually
> with the same
> problem.
> Could it be worth a try to delete the postgis-2.0.so
> <http://postgis-2.0.so>
> <http://postgis-2.0.so> file and reinstall postgis?
> I don't think it is related to postgis-2.0.so
> <http://postgis-2.0.so>, but really to the mess with GEOS installs.
> Try to make sure that you're using the correct geos-config. If
> you're using a Linux OS, you can try:
> sudo updatedb
> locate geos-config
> See how many do you have. Mine (compiled by myself) is in
> '/usr/local/bin/geos-config'. You can check if it is the correct
> one with, e.g. less:
> less /usr/local/bin/geos-config
> It shows me somewhere that this is the 3.4.0dev version:
> --version)
> echo 3.4.0dev
> Then I can use:
> --with-geosconfig=/usr/local/__bin/geos-config
> Now you have to adjust it for your needs. How did you install GEOS
> 3.3.2? Did you use a package manager, or compile it manually? Only
> this will tell you which geos-config to use...
> Mathieu.
> Hi Mathieu,
> I have compiled my geos myself using ./autogen.sh, ./configure, make,
> make install.
> Then i set the path to the geos-config manually when configuring postgis:
> ./configure --with-geosconfig=/usr/local/bin/geos-config --with raster
> I also tried by reinstalling the latest geos3.4.dev from trunk.
> However. I get the same error:
> ---- Making check in liblwgeom
> make[1]: Entering directory
> `/home/andreas/Downloads/postgis-2.0.0alpha3SVN/liblwgeom'
> make -C cunit check
> make[2]: Entering directory
> `/home/andreas/Downloads/postgis-2.0.0alpha3SVN/liblwgeom/cunit'
> /bin/bash ../../libtool --mode=link gcc -g -O2 -Wall
> -Wmissing-prototypes -I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -o
> cu_tester cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o
> cu_geodetic.o cu_geos.o cu_measures.o cu_node.o cu_libgeom.o cu_split.o
> cu_surface.o cu_homogenize.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o
> cu_out_kml.o cu_out_geojson.o cu_out_svg.o cu_out_x3d.o cu_in_wkb.o
> cu_in_wkt.o cu_tester.o ../liblwgeom.la <http://liblwgeom.la> -lcunit
> libtool: link: gcc -g -O2 -Wall -Wmissing-prototypes
> -I/usr/local/include -DPOSTGIS_GEOS_VERSION=34 -o .libs/cu_tester
> cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o cu_geodetic.o
> cu_geos.o cu_measures.o cu_node.o cu_libgeom.o cu_split.o cu_surface.o
> cu_homogenize.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o cu_out_kml.o
> cu_out_geojson.o cu_out_svg.o cu_out_x3d.o cu_in_wkb.o cu_in_wkt.o
> cu_tester.o ../.libs/liblwgeom.so /usr/lib/libcunit.so
> #gcc -o cu_tester cu_algorithm.o cu_print.o cu_misc.o cu_ptarray.o
> cu_in_wkt.o cu_tester.o ../.libs/liblwgeom.a -lm -lcunit
> -L/usr/local/lib -lgeos_c
> /home/andreas/Downloads/postgis-2.0.0alpha3SVN/liblwgeom/cunit/.libs/lt-cu_tester:
> error while loading shared libraries: libgeos-3.4.0dev.so
> <http://libgeos-3.4.0dev.so>: cannot open shared object file: No such
> file or directory
> make[2]: *** [check] Error 127
> make[2]: Leaving directory
> make[1]: *** [check] Error 2
> make[1]: Leaving directory
> make: *** [check] Error 1
> Andreas
> <mailto:basille at ase-research.__org
> <mailto:basille at ase-research.org>>>
> It seems indeed to be related to your previous GEOS
> install. What
> command did you use to compile PostGIS? Is it possible that
> the path to
> geos-config is still linking to the previous install? You
> can override
> it by: '--with-geosconfig=/usr/bin/____geos-config' (or the
> one related
> to your current install of GEOS) in the ./configure.
> Hope it helps. If not, please provide more details (OS,
> previous
> commands, etc.).
> Mathieu.
> Le 31/01/2012 09:33, Andreas Forø Tollefsen a écrit :
> Hi,
> I have installed GEOS 3.3.2 and GDAL 1.9.
> I previously had a GEOS SVN 3.4 installed, but no longer.
> Still i get this error when running make check.
> Any idea?
> /home/andreas/Downloads/____postgis-2.0.0alpha3SVN/____liblwgeom/cunit/.libs/lt-cu_____testr:
> such file
> or directory
> `/home/andreas/Downloads/____postgis-2.0.0alpha3SVN/____liblwgeom/cunit'
> `/home/andreas/Downloads/____postgis-2.0.0alpha3SVN/____liblwgeom'
> ___________________________________________________
> postgis-users mailing list
> postgis-users at postgis.__refrac__tions.net
> <http://refractions.net>
> <mailto:postgis-users at postgis.__refractions.net
> <mailto:postgis-users at postgis.refractions.net>>
> http://postgis.refractions.____net/mailman/listinfo/postgis-____users
> <http://postgis.refractions.__net/mailman/listinfo/postgis-__users
> <http://postgis.refractions.net/mailman/listinfo/postgis-users>>
> ~$ whoami
> Mathieu Basille, Post-Doc
> ~$ locate
> Laboratoire d'Écologie Comportementale et de Conservation
> de la Faune
> + Centre d'Étude de la Forêt
> Département de Biologie
> Université Laval, Québec
> ~$ info
> http://ase-research.org/____basille
> <http://ase-research.org/__basille>
> <http://ase-research.org/basille>>
> ~$ fortune
> ``If you can't win by reason, go for volume.''
> Calvin, by Bill Watterson.
> ~$ whoami
> ~$ locate
> Laboratoire d'Écologie Comportementale et de Conservation de la Faune
> ~$ info
> http://ase-research.org/__basille <http://ase-research.org/basille>
> ~$ fortune
~$ whoami
~$ locate
~$ info
~$ fortune
