[postgis-users] raster2pgsql loader error
Andreas Forø Tollefsen andreasft at gmail.com
Tue Jan 31 11:25:23 PST 2012
I now see that the Warning 6 message is always present but the data are
still converted to sql.
However, the
lt-raster2pgsql: rt_api.c:4281: rt_raster_set_srid: Assertion `((void *)0)
!= raster' failed.
message aborts the conversion.
2012/1/31 Andreas Forø Tollefsen <andreasft at gmail.com>
> Hi all,
> Updated to latest subversion and tried the new loader for the first time.
> However, i recieve the error below.
> Never seen this error before using raster2pgsql.py script, but apparently,
> quite some changes have occured since then.
> andreas at andreas-priogrid:/mnt/pc258/prio_grid/source/access/access_50k/acc_50k$
> raster2pgsql -s 4326 -I w001001.adf poptest > /home/andreas/poptest1.sql
> Processing 1/1: w001001.adf
> Warning 6: A dataset opened by GDALOpenShared should have the same
> filename (w001001.adf) and description (.)
> != raster' failed.
> Aborted
> Any ideas?
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120131/27ecdea9/attachment.html>
