[postgis-users] Super weird problem: ST_GeomFromText('POINT(-114.112534 50.895364)') works, ST_GeomFromText('POINT(-114.228869 51.152249)') fails -- why?
René Fournier
m5 at renefournier.com
Mon Jul 2 04:10:55 PDT 2012
If I try to insert a row containing particular coordinate, the query fails and the DB connection is lost. (By comparison, hundreds of inserts of other coordinates work fine.) Here's a straight copy-and-paste comparison from psql:
mydb=# INSERT INTO addresses ( account_id, territory_id, location ) VALUES ( 1, 0, ST_GeomFromText('POINT(-114.112534 50.895364)') ) RETURNING id;
id
333
(1 row)
INSERT 0 1
mydb=# INSERT INTO addresses ( account_id, territory_id, location ) VALUES ( 1, 0, ST_GeomFromText('POINT(-114.228869 51.152249)') ) RETURNING id;
The connection to the server was lost. Attempting reset: Failed.
Here's the table definition:
CREATE TABLE public.addresses
(id serial NOT NULL,
account_id int NOT NULL,
territory_id int NOT NULL,
location GEOGRAPHY(POINT,4326),
PRIMARY KEY (id));
CREATE INDEX location ON addresses USING GIST (location);
Strange right? FWIW, the queries are being generated programmatically by a script, so the error is not caused by a typo, since hundreds of other inserts work. Also, I've done a little research, two interesting findings:
1. All the multiplied coordinate values (abs(lat)*abs(lng)) of the SUCCESSFUL inserts are LOWER than the coordinates of failed query.
2. If I create the table without the index on location, the failed inserts suddenly work. So it seems the problem lies with the PostGIS updating the Index -- maybe it doesn't like the size of the values of the larger coordinates?
Anyway, if you have any ideas of what I can do to fix this, I would love to hear them. Thanks!
...Rene
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120702/9eeda262/attachment.html>
