[postgis-users] pgsql2shp
James Sewell
James.Sewell at lisasoft.com
Mon Jul 2 23:14:18 PDT 2012
Hello,
When I run pgsql2shp like so:
pgsql2shp -u plm25 -g the_geom database table
I get the following output:
Xcolumn number -1 is out of range 0..1
This continues in blocks for (I assume) each row in the table.
When I go to load the shape I get null values for all rows as follows:
INSERT INTO "table" (the_geom) VALUES (NULL);
My versions are:
PostgreSQL 9.1.4 on sparc-sun-solaris2.10, compiled by cc: Sun C 5.11 SunOS_sparc 145354-05 2011/09/13, 64-bit
POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.1, released 2012/05/15 GDAL_DATA not found" LIBXML="2.7.8" LIBJSON="UNKNOWN" R
ASTER
Any ideas? This is a fresh table, not migrated form an old version.
Cheers,
James Sewell
Solutions Architect
LISAsoft
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
