[postgis-users] Super weird problem: Cannot insert more than ~300 rows (or ~100 kb) into a table
René Fournier m5 at renefournier.com
Tue Jul 3 05:03:57 PDT 2012
On 2012-07-03, at 1:43 PM, Mark Cave-Ayland wrote:
> On 03/07/12 12:34, René Fournier wrote:
>> If I quit and restart psql, same error occurs. Only if I drop the table
>> can I insert more rows — but again, only up to around 300 rows or 100 kb
>> (not sure where the limit is)... So, it's not dependent on the kind of
>> coordinates or row data, just the number of inserts and/or the amount of
>> data. Any ideas what is causing the problem here?
> Strange - from what you're saying, it sounds as if it could be to do with the index splitting code, but without a backtrace (http://trac.osgeo.org/postgis/wiki/DevWikiGettingABackTrace) it's tricky to say exactly.
> One small nit - I notice you've got a geography column but you're using ST_GeomFromText() rather than ST_GeogFromText() which is likely introducing an extra cast somewhere. Does changing to ST_GeogFromText() help prevent the crash at all?
Hi Mark,
Thanks for the tip... I changed to GeogFromText(), but the error/crash still occurs, at the same point...  After the crash, here's what the tables look like:
                              List of relations
 Schema |        Name        |   Type   |  Owner   |    Size    | Description
 public | accounts           | table    | postgres | 8192 bytes |
 public | accounts_id_seq    | sequence | postgres | 8192 bytes |
 public | addresses          | table    | postgres | 96 kB      |
 public | addresses_id_seq   | sequence | postgres | 8192 bytes |
 public | geography_columns  | view     | postgres | 0 bytes    |
 public | geometry_columns   | table    | postgres | 8192 bytes |
 public | languages          | table    | postgres | 8192 bytes |
 public | languages_id_seq   | sequence | postgres | 8192 bytes |
 public | spatial_ref_sys    | table    | postgres | 3000 kB    |
 public | territories        | table    | postgres | 416 kB     |
 public | territories_id_seq | sequence | postgres | 8192 bytes |
 public | users              | table    | postgres | 96 kB      |
 public | users_id_seq       | sequence | postgres | 8192 bytes |
Is it strange that the geography_columns view is 0 bytes? Even though both territories and addresses have a geography column (POLYGON and POINT respectively) and an associated GIST index?
...Rene
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120703/aa685f47/attachment.html>
