[postgis-users] Super weird problem: Cannot insert more than ~300 rows (or ~100 kb) into a table
Paul Ramsey
pramsey at opengeo.org
Wed Jul 4 14:46:47 PDT 2012
This is all well and good, but we need to know which 300 rows to load.
If you have a load file, just strip out the first 301 (or whatever)
rows, confirm that the file makes things go "boom" and then create a
ticket on the tracker with the dump file attached.
http://trac.osgeo.org/
Thanks!
P.
On Wed, Jul 4, 2012 at 2:01 AM, René Fournier <m5 at renefournier.com> wrote:
> I've narrowed the point at which a crash will always happen: If I simply
> create the table *without* the index...
> CREATE INDEX address_location ON addresses USING GIST (location);
> ...it won't crash. (Inserts thousands of rows without a problem.) With that
> index in place, it will always crash after ~300 rows. And here's the log
> when it does crash:
> LOG: server process (PID 98414) was terminated by signal 11: Segmentation
> fault
> LOG: terminating any other active server processes
> WARNING: terminating connection because of crash of another server process
> DETAIL: The postmaster has commanded this server process to roll back the
> current transaction and exit, because another server process exited
> abnormally and possibly corrupted shared memory.
> HINT: In a moment you should be able to reconnect to the database and
> repeat your command.
> LOG: all server processes terminated; reinitializing
> LOG: database system was interrupted; last known up at 2012-07-04 10:44:15
> CEST
> LOG: database system was not properly shut down; automatic recovery in
> progress
> LOG: redo starts at 0/78E4A50
> LOG: record with zero length at 0/7B52580
> LOG: redo done at 0/7B52540
> LOG: last completed transaction was at log time 2012-07-04
> 10:44:40.712517+02
> LOG: database system is ready to accept connections
> On 2012-07-03, at 6:31 PM, Mark Cave-Ayland wrote:
> On 03/07/12 13:20, René Fournier wrote:
> So, it seems that the table gets full and corrupted to some extent.
> After my import script inserts ~290 rows, and then postgres crashes...
> mydb=# select count(*) from addresses;INSERT INTO addresses (
> account_id, territory_id, location ) VALUES ( 1, 75,
> ST_GeomFromText('POINT(-114.267388 51.089941)') );
> count
> 284
> (1 row)
> The connection to the server was lost. Attempting reset: Failed.
> So, can't insert any more rows...
> !> delete from addresses where id > 50;
> You are currently not connected to a database.
> Postgres client/connection is crashed.
> !> \q
> Tue Jul 03 14:15:28 -- rene /opt/local/var/db:: psql -U postgres
> mydb psql (9.1.4)
> Type "help" for help.
> mydb=# delete from addresses where id > 50;
> DELETE 234
> Deleting rows works...
> count
> 50
> (1 row)
> SELECT and DELETE work, but I can't insert any new rows, until...
> !> \q
> Tue Jul 03 14:15:39 -- rene /opt/local/var/db:: psql -U postgres
> mydb psql (9.1.4)
> mydb=# vacuum;vacuum full;vacuum full analyze;
> VACUUM
> VACUUM
> NOTICE: no notnull values, invalid stats
> VACUUM
> count
> 50
> (1 row)
> INSERT 0 1
> mydb=#
> So, it appears there's some weird corruption going on... Still, not sure
> what to try next. My PostGIS is via Macports, not sure how to enable the
> debug mode...
> Hi René,
> I think that you need to create a new bug on the PostGIS bug tracker and
> upload a file that causes the crash on your system, i.e. it can be run using
> "psql -d postgis_db -f crash.sql" so that we can try and reproduce what you
> are seeing.
> Also as a matter of interest, do you see anything interesting in the
> PostgreSQL log file at the time of the crash?
> ATB,
> Mark.
> postgis-users mailing list
