[postgis-users] Updated PostGIS 2.0 Ubuntu 12.04 install instructions posted
GregoryKramdia algomorph at gmail.com
Wed Jul 4 15:12:51 PDT 2012
Thanks for you reply and my apologies,
I've run update & upgrade on the system from all sources just before
attempting the whole process, but I've should have run it after installing
the prerequisites. Apparently, something needed an upgrade.
After runing the ./configure process again, I got
"checking for library containing GDALAllRegister... none required"
I guess something indirectly fixed the problem.
Everything else worked fine.
View this message in context: http://postgis.17.n6.nabble.com/Updated-PostGIS-2-0-Ubuntu-12-04-install-instructions-posted-tp4955872p4998774.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
