[postgis-users] Better way of removing pixelation with postgis raster
Tom van Tilburg
tom.van.tilburg at gmail.com
Fri Jul 6 06:36:37 PDT 2012
Hi list,
Im trying to create a landuse map for a customer that requires the
removal of pixelation (isolated islands of pixels, possible larger than
1 pixel).
To make things complicated, different pixelclasses have different
tresholds for removal.
For instance, class 1 is removed when the combined pixels are less than
4, whereas class2 is removed when the combined pixels are less than 50.
Furthermore, some classes count diagonal neighbours as 'touching'
whereas other classes discard them.
My solution is given below.
As you can see there is an expensive buffer-union-buffer trio to make
sure I connect the correct polygons before I can calculate their area.
This calculation is part of a big raster calculation. All of the
calculations are going very fast, except this one.
Anyone with an idea to make it faster? In the end all I need is removal
of isolated islands of pixels so any matrix calculation would be fine as
well.
thanks, Tom
WITH
--Dump to polygons
polygons As
SELECT (ST_DumpAsPolygons(rast)).geom geom,
(ST_DumpAsPolygons(rast)).val val
FROM out_landuse_rast_30
--Merge polygons
,polygons_dissolved As
SELECT
ST_Buffer((ST_Dump(ST_Union(ST_Buffer(geom,1)))).geom,-1) geom, val
FROM polygons
GROUP BY val
--Select polygons that should go out
,polygons_out As
SELECT St_Collect(geom) geom FROM polygons_dissolved
WHERE
(ST_Area(geom) >= ((30*30) * 4) --4 pixels
AND val IN (1)
OR
(ST_Area(geom) >= ((30*30) * 50) --50 pixels
AND val IN (2)
--Create raster (mask) that should go out
SELECT 1 As rid, ST_AsRaster(a.geom, b.rast, '8BUI',1,0,false) rast
FROM polygons_out a, emptycanvas30 b;
