[postgis-users] I'm so close!
Eric Aspengren
ericaspen at gmail.com
Mon Jul 9 09:30:06 PDT 2012
And yet...
I've gotten just about everything done in a PostGIS/Tiger Geocoder install
and I get to create_geocode.sh and get a few problems.
I couldn't this problem being addressed on this list or anywhere else. Any
ideas?
I get this after all the tables are generated:
psql:census_loader.sql:102: NOTICE: function
loader_generate_census(text[],text) does not exist, skipping
DROP FUNCTION
CREATE FUNCTION
DELETE 0
INSERT 0 1
INSERT 0 1
INSERT 0 1
create_census_base_tables
Tables already present
(1 row)
SET
BEGIN
psql:create_geocode.sql:23: NOTICE: type "norm_addy" does not exist,
skipping
DROP TYPE
CREATE TYPE
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
psql:utility/levenshtein_ignore_case.sql:5: ERROR: function
levenshtein(text, text) does not exist
LINE 3: SELECT levenshtein(upper($1), upper($2));
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
psql:normalize/end_soundex.sql:17: ERROR: current transaction is aborted,
commands ignored until end of transaction block
psql:normalize/count_words.sql:32: ERROR: current transaction is aborted,
psql:normalize/state_extract.sql:90: ERROR: current transaction is
aborted, commands ignored until end of transaction block
psql:normalize/get_last_words.sql:29: ERROR: current transaction is
psql:normalize/location_extract_countysub_exact.sql:56: ERROR: current
transaction is aborted, commands ignored until end of transaction block
psql:normalize/location_extract_countysub_fuzzy.sql:89: ERROR: current
psql:normalize/location_extract_place_exact.sql:62: ERROR: current
psql:normalize/location_extract_place_fuzzy.sql:90: ERROR: current
psql:normalize/location_extract.sql:85: ERROR: current transaction is
psql:normalize/normalize_address.sql:708: ERROR: current transaction is
psql:normalize/pprint_addy.sql:10: ERROR: current transaction is aborted,
psql:normalize/pprint_addy.sql:43: ERROR: current transaction is aborted,
psql:geocode/other_helper_functions.sql:14: ERROR: current transaction is
psql:geocode/other_helper_functions.sql:22: ERROR: current transaction is
psql:geocode/other_helper_functions.sql:32: ERROR: current transaction is
psql:geocode/other_helper_functions.sql:48: ERROR: current transaction is
psql:geocode/other_helper_functions.sql:58: ERROR: current transaction is
psql:geocode/other_helper_functions.sql:201: ERROR: current transaction is
psql:geocode/other_helper_functions.sql:213: ERROR: current transaction is
psql:geocode/other_helper_functions.sql:240: ERROR: current transaction is
psql:geocode/other_helper_functions.sql:252: ERROR: current transaction is
psql:geocode/rate_attributes.sql:29: ERROR: current transaction is
psql:geocode/rate_attributes.sql:80: ERROR: current transaction is
psql:geocode/includes_address.sql:94: ERROR: current transaction is
psql:geocode/interpolate_from_address.sql:94: ERROR: current transaction
psql:geocode/geocode_address.sql:435: ERROR: current transaction is
psql:geocode/geocode_location.sql:99: ERROR: current transaction is
psql:geocode/geocode_intersection.sql:148: ERROR: current transaction is
psql:geocode/geocode.sql:37: ERROR: current transaction is aborted,
psql:geocode/geocode.sql:131: ERROR: current transaction is aborted,
psql:geocode/reverse_geocode.sql:222: ERROR: current transaction is
psql:geocode/census_tracts_functions.sql:57: ERROR: current transaction is
ROLLBACK
CREATE FUNCTION
ERROR: function least_hn(character varying, character varying) does not
exist
LINE 1: ...idx_tiger_addr_least_address ON addr USING btree (least_hn(f...
Eric Aspengren
(402) 478-VOTE
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120709/f39ce572/attachment.html>
