[postgis-users] possible bug: function st_asgeojson(geometry) is not unique
Sandro Santilli
strk at keybit.net
Tue Jul 10 03:16:35 PDT 2012
On Tue, Jul 10, 2012 at 11:57:33AM +0200, Tom van Tilburg wrote:
> I upgraded my postgis libraries from 2.0.0 to 2.0.1 but did a clean
> install with CREATE EXTENSION to a new database after that.
Could be a bug with CREATE EXTENSION. Could you try with "the old way"
to confirm ? If confirmed, this will be very worth opening a ticket for.
> Also I see no double functions in public.functions nor are there
> functions in any other place installed in the database.
select * from pg_proc where proname = 'st_asgeojson';
(I have 5 rows)
> version output is:
> "POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0,
> 6 March 2012" GDAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8"
> TOPOLOGY RASTER"
> Does it work for you?
Yes, but only tried on a pre-existing database, and not enabled
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.1
| / 2.1 | http://strk.keybit.net - http://vizzuality.com
`-o------'
