[postgis-users] Super weird problem: Cannot insert more than ~300 rows (or ~100 kb) into a table
Fred Lehodey
lehodey at gmail.com
Tue Jul 10 05:52:13 PDT 2012
no problem with :
"POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21 August 2008"
LIBXML="2.7.6" USE_STATS"
"POSTGIS="1.5.3" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.6.1, 21 August 2008"
LIBXML="2.7.8" USE_STATS"
"POSTGIS="2.0.0 r9605" GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March
2012" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
LIBJSON="UNKNOWN" (core procs from "2.0.0beta2 r9428" need upgrade)
(topology procs from "2.0.0beta2 r9428" need upgrade) (raster procs from
"2.0.0beta2 r9428" need upgrade)"
Fred
On Tue, Jul 10, 2012 at 1:06 PM, Nicolas Ribot <nicolas.ribot at gmail.com>wrote:
> > Ticket submitted:
> > http://trac.osgeo.org/postgis/ticket/1903
> > But the crash problem seems not to happen for everyone. At least, the
> attached SQL file will crash my PostgreSQL 1.5.4 on Mac OS X 10.7.4 every
> time. But not for Paul. Would some of you be able to test it on your setup,
> to see if we can spot a pattern or connection? Thanks.
> Hi,
> Made some tests with different versions:
> _____________________________________
> Test 1: Pgis 1.5.3
> postgis_full_version
> POSTGIS="1.5.3" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March
> 2012" LIBXML="2.7.3" USE_STATS
> (1 row)
> Time: 16.980 ms
> postgis15=# select version();
> version
> PostgreSQL 9.1.1 on x86_64-apple-darwin11.1.0, compiled by
> i686-apple-darwin11-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc.
> build 5658) (LLVM build 2335.15.00), 64-bit
> (1 row)
> => Passed.
> Test 2:
> Same Postgresql, postgis 2.0:
> POSTGIS="2.0.0" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March
> 2012" LIBXML="2.7.3" USE_STATS (procs from 2.0 r7948 need upgrade)
> => passed
> Test 3: postgis 1.5.4
> POSTGIS="1.5.4" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March
> 2012" LIBXML="2.7.8" USE_STATS
> => crashes:
> server process (PID 11035) was terminated by signal 11: Segmentation fault
> psql:/Users/nicolas/Downloads/test.sql:289: connection to server was lost
> LOG: terminating any other active server processes
> LOG: all server processes terminated; reinitializing
> LOG: database system was interrupted; last known up at 2012-07-10
> 14:02:44 CEST
> LOG: database system was not properly shut down; automatic recovery in
> progress
> LOG: consistent recovery state reached at 1E/92D6D278
> LOG: redo starts at 1E/92D6D278
> LOG: record with zero length at 1E/932A6558
> LOG: redo done at 1E/932A6518
> LOG: last completed transaction was at log time 2012-07-10
> 14:05:10.908316+02
> LOG: database system is ready to accept connections
> Nicolas
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120710/3c5866dc/attachment.html>
