[postgis-users] Super weird problem: Cannot insert more than ~300 rows (or ~100 kb) into a table
Nicolas Ribot
nicolas.ribot at gmail.com
Tue Jul 10 06:20:49 PDT 2012
Hi Sandro,
I will complete the ticket.
Reproducing consistently: not sure how to proceed, but I tested on 2
different databases (same PG version): one freshly created with pgis
1.5.4, one that did not contain postgis but contained several tables.
Then postgis was added to this DB and the test file was executed
against it: it also crashed.
Nicolas
On 10 July 2012 15:00, Sandro Santilli <strk at keybit.net> wrote:
> Nicolas: could you update the ticket with this indication ?
> Sounds like a regression introduced by 1.5.4 : can you reproduce
> consistently with that setup ?
> --strk;
> On Tue, Jul 10, 2012 at 02:06:43PM +0200, Nicolas Ribot wrote:
>> > Ticket submitted:
>> > http://trac.osgeo.org/postgis/ticket/1903
>> > But the crash problem seems not to happen for everyone. At least, the attached SQL file will crash my PostgreSQL 1.5.4 on Mac OS X 10.7.4 every time. But not for Paul. Would some of you be able to test it on your setup, to see if we can spot a pattern or connection? Thanks.
>> Hi,
>> Made some tests with different versions:
>> _____________________________________
>> Test 1: Pgis 1.5.3
>> postgis_full_version
>> POSTGIS="1.5.3" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March
>> 2012" LIBXML="2.7.3" USE_STATS
>> (1 row)
>> Time: 16.980 ms
>> postgis15=# select version();
>> version
>> PostgreSQL 9.1.1 on x86_64-apple-darwin11.1.0, compiled by
>> i686-apple-darwin11-llvm-gcc-4.2 (GCC) 4.2.1 (Based on Apple Inc.
>> build 5658) (LLVM build 2335.15.00), 64-bit
>> (1 row)
>> => Passed.
>> Test 2:
>> Same Postgresql, postgis 2.0:
>> POSTGIS="2.0.0" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March
>> 2012" LIBXML="2.7.3" USE_STATS (procs from 2.0 r7948 need upgrade)
>> => passed
>> Test 3: postgis 1.5.4
>> POSTGIS="1.5.4" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March
>> 2012" LIBXML="2.7.8" USE_STATS
>> => crashes:
>> server process (PID 11035) was terminated by signal 11: Segmentation fault
>> psql:/Users/nicolas/Downloads/test.sql:289: connection to server was lost
>> LOG: terminating any other active server processes
>> LOG: all server processes terminated; reinitializing
>> LOG: database system was interrupted; last known up at 2012-07-10 14:02:44 CEST
>> LOG: database system was not properly shut down; automatic recovery in progress
>> LOG: consistent recovery state reached at 1E/92D6D278
>> LOG: redo starts at 1E/92D6D278
>> LOG: record with zero length at 1E/932A6558
>> LOG: redo done at 1E/932A6518
>> LOG: last completed transaction was at log time 2012-07-10 14:05:10.908316+02
>> LOG: database system is ready to accept connections
>> Nicolas
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.1
> | / 2.1 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
