[postgis-users] Super weird problem: Cannot insert more than ~300 rows (or ~100 kb) into a table
Paul Ramsey
pramsey at opengeo.org
Tue Jul 10 09:53:56 PDT 2012
Indeed, there has been a small change since 1.5.4 that moves some
testing for unknowns *below* the null test (where they should be)
avoiding the null pointer reference that is causing the crash.
Index: postgis/geography_gist.c
--- postgis/geography_gist.c (revision 9721)
+++ postgis/geography_gist.c (revision 10037)
@@ -267,17 +267,15 @@
return 0.0;
- if ( gidx_is_unknown(a) && gidx_is_unknown(b) )
- return 0.0;
if ( a == NULL || gidx_is_unknown(a) )
return gidx_volume(b);
if ( b == NULL || gidx_is_unknown(b) )
return gidx_volume(a);
+ if ( gidx_is_unknown(a) && gidx_is_unknown(b) )
+ return 0.0;
/* Ensure 'a' has the most dimensions. */
gidx_dimensionality_check(&a, &b);
On Tue, Jul 10, 2012 at 9:50 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Since others get crashes on 1.5.4, I tested *exactly* that version and
> lo, it does in fact crash. The current 1.5 stable branch does not
> crash, so finding the different might not be hard... (also points to
> needing a 1.5.5)
> P.
> On Tue, Jul 10, 2012 at 1:00 AM, René Fournier <m5 at renefournier.com> wrote:
>> Ticket submitted:
>> http://trac.osgeo.org/postgis/ticket/1903
>> But the crash problem seems not to happen for everyone. At least, the attached SQL file will crash my PostgreSQL 1.5.4 on Mac OS X 10.7.4 every time. But not for Paul. Would some of you be able to test it on your setup, to see if we can spot a pattern or connection? Thanks.
>> On 2012-07-04, at 11:46 PM, Paul Ramsey wrote:
>>> This is all well and good, but we need to know which 300 rows to load.
>>> If you have a load file, just strip out the first 301 (or whatever)
>>> rows, confirm that the file makes things go "boom" and then create a
>>> ticket on the tracker with the dump file attached.
>>> Thanks!
>>> P.
>>> On Wed, Jul 4, 2012 at 2:01 AM, René Fournier <m5 at renefournier.com> wrote:
>>>> I've narrowed the point at which a crash will always happen: If I simply
>>>> create the table *without* the index...
>>>> CREATE INDEX address_location ON addresses USING GIST (location);
>>>> ...it won't crash. (Inserts thousands of rows without a problem.) With that
>>>> index in place, it will always crash after ~300 rows. And here's the log
>>>> when it does crash:
>>>> LOG: server process (PID 98414) was terminated by signal 11: Segmentation
>>>> fault
>>>> LOG: terminating any other active server processes
>>>> WARNING: terminating connection because of crash of another server process
>>>> DETAIL: The postmaster has commanded this server process to roll back the
>>>> current transaction and exit, because another server process exited
>>>> abnormally and possibly corrupted shared memory.
>>>> HINT: In a moment you should be able to reconnect to the database and
>>>> repeat your command.
>>>> LOG: all server processes terminated; reinitializing
>>>> LOG: database system was interrupted; last known up at 2012-07-04 10:44:15
>>>> CEST
>>>> LOG: database system was not properly shut down; automatic recovery in
>>>> progress
>>>> LOG: redo starts at 0/78E4A50
>>>> LOG: record with zero length at 0/7B52580
>>>> LOG: redo done at 0/7B52540
>>>> LOG: last completed transaction was at log time 2012-07-04
>>>> 10:44:40.712517+02
>>>> LOG: database system is ready to accept connections
>>>> On 2012-07-03, at 6:31 PM, Mark Cave-Ayland wrote:
>>>> On 03/07/12 13:20, René Fournier wrote:
>>>> So, it seems that the table gets full and corrupted to some extent.
>>>> After my import script inserts ~290 rows, and then postgres crashes...
>>>> mydb=# select count(*) from addresses;INSERT INTO addresses (
>>>> account_id, territory_id, location ) VALUES ( 1, 75,
>>>> ST_GeomFromText('POINT(-114.267388 51.089941)') );
>>>> count
>>>> 284
>>>> (1 row)
>>>> The connection to the server was lost. Attempting reset: Failed.
>>>> So, can't insert any more rows...
>>>> !> delete from addresses where id > 50;
>>>> You are currently not connected to a database.
>>>> Postgres client/connection is crashed.
>>>> !> \q
>>>> Tue Jul 03 14:15:28 -- rene /opt/local/var/db:: psql -U postgres
>>>> mydb psql (9.1.4)
>>>> Type "help" for help.
>>>> mydb=# delete from addresses where id > 50;
>>>> DELETE 234
>>>> Deleting rows works...
>>>> count
>>>> 50
>>>> (1 row)
>>>> SELECT and DELETE work, but I can't insert any new rows, until...
>>>> !> \q
>>>> Tue Jul 03 14:15:39 -- rene /opt/local/var/db:: psql -U postgres
>>>> mydb psql (9.1.4)
>>>> mydb=# vacuum;vacuum full;vacuum full analyze;
>>>> VACUUM
>>>> VACUUM
>>>> NOTICE: no notnull values, invalid stats
>>>> VACUUM
>>>> count
>>>> 50
>>>> (1 row)
>>>> INSERT 0 1
>>>> mydb=#
>>>> So, it appears there's some weird corruption going on... Still, not sure
>>>> what to try next. My PostGIS is via Macports, not sure how to enable the
>>>> debug mode...
>>>> Hi René,
>>>> I think that you need to create a new bug on the PostGIS bug tracker and
>>>> upload a file that causes the crash on your system, i.e. it can be run using
>>>> "psql -d postgis_db -f crash.sql" so that we can try and reproduce what you
>>>> are seeing.
>>>> Also as a matter of interest, do you see anything interesting in the
>>>> PostgreSQL log file at the time of the crash?
>>>> ATB,
>>>> Mark.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
