[postgis-users] St_Area to acres
Birgit Laggner
birgit.laggner at vti.bund.de
Wed Jul 11 03:36:23 PDT 2012
I was looking at spatialreference.org <http://spatialreference.org>,
too, and did find EPSG 102686, which has US-foot as projection unit and
is meant for the same region as 26986...
Regards,
Birgit.
Am 10.07.2012 15:26, schrieb Nathan Gerber:
> In looking at EPSG:26986 on spatialreference.org
> <http://spatialreference.org> (
> http://spatialreference.org/ref/epsg/26986/ ) it appears that the
> projection's native units are meters rather than feet. If you divide
> by 4046.85642 (number of square meters in an acre) your acreage
> numbers will come out much closer than they are at present but will
> still be a bit off.
> Nathan Gerber
> On Mon, Jul 9, 2012 at 11:44 PM, Daniel Cole
> <daniel at southernsolutionsms.com
> <mailto:daniel at southernsolutionsms.com>> wrote:
> I am using the code below:
> *Select name, acreage, ST_Area(ST_Transform(geom, 26986))/43560 as
> acres from ss.fields*
> and getting these results.
> name acreage acres
> H 01
> 15.79
> 1.50398045317257
> H 02
> 29.02
> 2.76480120804097
> H 03
> 31.95
> 3.04337512685165
> H 04
> 34.71
> 3.30710750534269
> H 05
> 111.6
> 10.6322788992474
> I have another program where I am importing the acreage data from
> and I just wanted it to match up in postgis well in case I ever
> wanted to calculate it myself. It seems that I am almost there,
> but I am a decimal off and I can't understand that.
> Also I am not very familiar with the 26986, but I used it because
> I saw it used for sqare feet somewhere else. Should I be using
> anything else?
> Thanks,
> DC
> postgis-users mailing list
> <mailto:postgis-users at postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120711/622f6aad/attachment.html>
