[postgis-users] Super weird problem: Cannot insert more than ~300 rows (or ~100 kb) into a table
René Fournier m5 at renefournier.com
Thu Jul 12 00:59:43 PDT 2012
Any ETA on 1.5.5? This bug in 1.5.4 is actually a show stopper for me... Thanks.
On 2012-07-10, at 10:46 PM, Paul Ramsey wrote:
> On Tue, Jul 10, 2012 at 12:24 PM, Sandro Santilli <strk at keybit.net> wrote:
>> Better cut a 1.5.5 soon.
>> Did the NEWS file contain a note about this already ?
> No, it was a teeny change that had no ticket :) I know, I'm bad. Has one now.
> P.
>> --strk;
>> On Tue, Jul 10, 2012 at 09:53:56AM -0700, Paul Ramsey wrote:
>>> Indeed, there has been a small change since 1.5.4 that moves some
>>> testing for unknowns *below* the null test (where they should be)
>>> avoiding the null pointer reference that is causing the crash.
>>> Index: postgis/geography_gist.c
>>> --- postgis/geography_gist.c    (revision 9721)
>>> +++ postgis/geography_gist.c    (revision 10037)
>>> @@ -267,17 +267,15 @@
>>>                return 0.0;
>>> -       if ( gidx_is_unknown(a) && gidx_is_unknown(b) )
>>> -               return 0.0;
>>>        if ( a == NULL || gidx_is_unknown(a) )
>>>                return gidx_volume(b);
>>>        if ( b == NULL || gidx_is_unknown(b) )
>>>                return gidx_volume(a);
>>> +       if ( gidx_is_unknown(a) && gidx_is_unknown(b) )
>>> +               return 0.0;
>>>        /* Ensure 'a' has the most dimensions. */
>>>        gidx_dimensionality_check(&a, &b);
>>> On Tue, Jul 10, 2012 at 9:50 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
>>>> Since others get crashes on 1.5.4, I tested *exactly* that version and
>>>> lo, it does in fact crash. The current 1.5 stable branch does not
>>>> crash, so finding the different might not be hard... (also points to
>>>> needing a 1.5.5)
>>>> P.
>>>> On Tue, Jul 10, 2012 at 1:00 AM, René Fournier <m5 at renefournier.com> wrote:
>>>>> Ticket submitted:
>>>>>        http://trac.osgeo.org/postgis/ticket/1903
>>>>> But the crash problem seems not to happen for everyone. At least, the attached SQL file will crash my PostgreSQL 1.5.4 on Mac OS X 10.7.4 every time. But not for Paul. Would some of you be able to test it on your setup, to see if we can spot a pattern or connection? Thanks.
>>>>> On 2012-07-04, at 11:46 PM, Paul Ramsey wrote:
>>>>>> This is all well and good, but we need to know which 300 rows to load.
>>>>>> If you have a load file, just strip out the first 301 (or whatever)
>>>>>> rows, confirm that the file makes things go "boom" and then create a
>>>>>> ticket on the tracker with the dump file attached.
>>>>>> Thanks!
>>>>>> P.
>>>>>> On Wed, Jul 4, 2012 at 2:01 AM, René Fournier <m5 at renefournier.com> wrote:
>>>>>>> I've narrowed the point at which a crash will always happen: If I simply
>>>>>>> create the table *without* the index...
>>>>>>> CREATE INDEX address_location ON addresses USING GIST (location);
>>>>>>> ...it won't crash. (Inserts thousands of rows without a problem.) With that
>>>>>>> index in place, it will always crash after ~300 rows. And here's the log
>>>>>>> when it does crash:
>>>>>>> LOG:  server process (PID 98414) was terminated by signal 11: Segmentation
>>>>>>> fault
>>>>>>> LOG:  terminating any other active server processes
>>>>>>> WARNING:  terminating connection because of crash of another server process
>>>>>>> DETAIL:  The postmaster has commanded this server process to roll back the
>>>>>>> current transaction and exit, because another server process exited
>>>>>>> abnormally and possibly corrupted shared memory.
>>>>>>> HINT:  In a moment you should be able to reconnect to the database and
>>>>>>> repeat your command.
>>>>>>> LOG:  all server processes terminated; reinitializing
>>>>>>> LOG:  database system was interrupted; last known up at 2012-07-04 10:44:15
>>>>>>> CEST
>>>>>>> LOG:  database system was not properly shut down; automatic recovery in
>>>>>>> progress
>>>>>>> LOG:  redo starts at 0/78E4A50
>>>>>>> LOG:  record with zero length at 0/7B52580
>>>>>>> LOG:  redo done at 0/7B52540
>>>>>>> LOG:  last completed transaction was at log time 2012-07-04
>>>>>>> 10:44:40.712517+02
>>>>>>> LOG:  database system is ready to accept connections
>>>>>>> On 2012-07-03, at 6:31 PM, Mark Cave-Ayland wrote:
>>>>>>> On 03/07/12 13:20, René Fournier wrote:
>>>>>>> So, it seems that the table gets full and corrupted to some extent.
>>>>>>> After my import script inserts ~290 rows, and then postgres crashes...
>>>>>>>  mydb=# select count(*) from addresses;INSERT INTO addresses (
>>>>>>>  account_id, territory_id, location ) VALUES ( 1, 75,
>>>>>>>  ST_GeomFromText('POINT(-114.267388 51.089941)') );
>>>>>>>  count
>>>>>>>  284
>>>>>>>  (1 row)
>>>>>>>  The connection to the server was lost. Attempting reset: Failed.
>>>>>>> So, can't insert any more rows...
>>>>>>>  !> delete from addresses where id > 50;
>>>>>>>  You are currently not connected to a database.
>>>>>>> Postgres client/connection is crashed.
>>>>>>>  !> \q
>>>>>>>  Tue Jul 03 14:15:28 -- rene /opt/local/var/db:: psql -U postgres
>>>>>>>  mydb psql (9.1.4)
>>>>>>>  Type "help" for help.
>>>>>>>  mydb=# delete from addresses where id > 50;
>>>>>>>  DELETE 234
>>>>>>> Deleting rows works...
>>>>>>>  count
>>>>>>>  50
>>>>>>>  (1 row)
>>>>>>> SELECT and DELETE work, but I can't insert any new rows, until...
>>>>>>>  !> \q
>>>>>>>  Tue Jul 03 14:15:39 -- rene /opt/local/var/db:: psql -U postgres
>>>>>>>  mydb psql (9.1.4)
>>>>>>>  mydb=# vacuum;vacuum full;vacuum full analyze;
>>>>>>>  VACUUM
>>>>>>>  VACUUM
>>>>>>>  NOTICE: no notnull values, invalid stats
>>>>>>>  VACUUM
>>>>>>>  count
>>>>>>>  50
>>>>>>>  (1 row)
>>>>>>>  INSERT 0 1
>>>>>>>  mydb=#
>>>>>>> So, it appears there's some weird corruption going on... Still, not sure
>>>>>>> what to try next. My PostGIS is via Macports, not sure how to enable the
>>>>>>> debug mode...
>>>>>>> Hi René,
>>>>>>> I think that you need to create a new bug on the PostGIS bug tracker and
>>>>>>> upload a file that causes the crash on your system, i.e. it can be run using
>>>>>>> "psql -d postgis_db -f crash.sql" so that we can try and reproduce what you
>>>>>>> are seeing.
>>>>>>> Also as a matter of interest, do you see anything interesting in the
>>>>>>> PostgreSQL log file at the time of the crash?
>>>>>>> ATB,
>>>>>>> Mark.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
