[postgis-users] ST_CreateTopoGeo doesn't insert into topo.relation
Astrid Bjørnerød
aeb at skogoglandskap.no
Thu Jul 12 22:50:58 PDT 2012
Thanks, now I have the topo_schema.relation table :-)
I had to SET search_path = '$user','test_ar5jm', 'topology','public';
before I ran the function because of topogeo_addpolygon .
Astrid
-----Opprinnelig melding-----
Fra: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] På vegne av Sandro Santilli
Sendt: 11. juli 2012 15:04
Til: PostGIS Users Discussion
Emne: Re: [postgis-users] ST_CreateTopoGeo doesn't insert into topo.relation
On Wed, Jul 11, 2012 at 12:34:05PM +0000, Astrid Bjørnerød wrote:
> Hei.
> I need the relation between geo and topo, and I have used a query like :
> select a.gid, f.face_id,a.geo,f.mbr,a.artype from
> test_ar5jm.temp_ar5_flate a, ar5_topo.face f, ar5_topo.relation r
> where r.topogeo_id = a.gid and r.element_id = f.face_id
> But sometimes the function ST_CreateTopoGeo doesn't populate the topo.relation table.
> I have unique id for my geometry-table so why doesn't the trigger insert?
ST_CreateTopoGeo _never_ touches the "relation" table.
That function only populates the primitives.
How could it know what makes up a feature, when its input is just a single geometry ?
If you want to create TopoGeometries (that's what "relation" is for) use the toTopoGeom function.
--strk;
,------o-.
| __/ | Delivering high quality PostGIS 2.1
| / 2.1 | http://strk.keybit.net - http://vizzuality.com
`-o------'
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
