[postgis-users] Make a 3D table in PostGIS
Mike Toews
mwtoews at gmail.com
Mon Jul 16 03:36:59 PDT 2012
If you are using PostGIS 2.0, you can use the typmod syntax by adding
"Z" to the geometry type. For example, Point -> PointZ:
CREATE TABLE my3d(
gid serial primary key,
geom geometry(PointZ),
name character varying(20) not null
Then you can use functions like ST_MakePoint [1] to construct a 3D
geometry to put in the table:
INSERT INTO my3d(geom, name)
SELECT ST_MakePoint(3.1, 4.2, 5.1), 'a 3D point';
[1] http://www.postgis.org/docs/ST_MakePoint.html
-Mike
On 16 July 2012 22:22, josamulai <jmamuedo at gmail.com> wrote:
> Hello.
> How can to make a 3D table from a file with x, y, z information?
> Thank you.
> View this message in context: http://postgis.17.n6.nabble.com/Make-a-3D-table-in-PostGIS-tp4998971.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
