[postgis-users] ST_Difference not working as aspected
fLaNsch at gmx.de
fLaNsch at gmx.de
Mon Jul 16 02:53:35 PDT 2012
Hi postgis-user,
i like to get the difference between n crossing exterior Linerings and n smaller polygons which are within the rings. In Quantum GIS everything works as aspected.
Scenario:
LineRing A
________
(________)
LineRing B
________
(________)
Situation between A and B
______________
(_____(__)_____)
Two smaller Polygons within the Linerings to erase the shared part of LineRing A and B. If i first use ST_Union to dissolve the Polygon Geometry everything works fine with st_difference, but ST_UNION is no option for a dataset > 4 million.
With the following SQL-Statement, i can extract the shared parts.
Select (st_dump(st_intersection(a.geom,b.geom))).geom as geom from line b, poly a where st_intersects(a.geom,b.geom)
But how to keep on? I'm stuck.
BIG THANKS for any kind of assistance!
Simon
