[postgis-users] spatialreference.org srid insert error
Peter Tittmann
ptittmann at gmail.com
Tue Jul 17 12:19:33 PDT 2012
Thanks Astrid!
Seems a little strange that spatialreference.org would produce an invalid insert statement. Regardless, thanks for the pointer.
Peter
Peter Tittmann
On Tuesday, July 17, 2012 at 1:09 PM, Astrid Emde wrote:
> Hello Peter,
> there is a constraint that checks that srid is < 998999
> ALTER TABLE spatial_ref_sys
> ADD CONSTRAINT spatial_ref_sys_srid_check CHECK (srid > 0 AND srid <=
> 998999);
> You should set sird in the insert to 102243 instead of 9102243:
> INSERT into spatial_ref_sys (srid, auth_name, auth_srid, proj4text,
> srtext) values
> ( 102243, 'esri', 102243, '+proj=lcc +lat_1=37.06666666666667
> +lat_2=38.43333333333333 +lat_0=36.5 +lon_0=-120.5 +x_0=2000000
> +y_0=500000 +ellps=GRS80 +units=m +no_defs ',
> 'PROJCS["NAD_1983_HARN_StatePlane_California_III_FIPS_0403",GEOGCS["GCS_North_American_1983_HARN",DATUM["NAD83_High_Accuracy_Regional_Network",SPHEROID["GRS_1980",6378137,298.257222101]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["False_Easting",2000000],PARAMETER["False_Northing",500000],PARAMETER["Central_Meridian",-120.5],PARAMETER["Standard_Parallel_1",37.06666666666667],PARAMETER["Standard_Parallel_2",38.43333333333333],PARAMETER["Latitude_Of_Origin",36.5],UNIT["Meter",1],AUTHORITY["EPSG","102243"]]');
> Astrid
> On Tue, July 17, 2012 6:14 pm, Peter Tittmann wrote:
> > Hi,
> > Im trying to add a srid from spatial reference.org (http://reference.org)
> > (http://spatialreference.org/ref/esri/102243/postgis/) but i'm getting a
> > error using the insert statement:
> > ERROR: new row for relation "spatial_ref_sys" violates check constraint
> > "spatial_ref_sys_srid_check"
> > I saw this ticket
> > (http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CDYQ
> > FjAA&url=http%3A%2F%2Ftrac.osgeo.org (http://2Ftrac.osgeo.org)%2Fpostgis%2Fticket%2F1505&ei=f6gFUOy
> > kJcWl2AXz2eDKBQ&usg=AFQjCNH1dlCvTvWEYntRmqflCDtAOUT49g&sig2=tch67lIoPp2IO
> > RZaCyOpSw) and thread
> > (http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CDgQ
> > FjAB&url=http%3A%2F%2Fpostgis.refractions.net (http://2Fpostgis.refractions.net)%2Fpipermail%2Fpostgis-devel
> > %2F2012-February%2F018485.html&ei=f6gFUOykJcWl2AXz2eDKBQ&usg=AFQjCNGxJREc
> > 0HrXIbAFuKSfvjU0tbfg9A&sig2=0wH8-t8hCMiuIWKDL6AeFQ) but seems lie it
> > should be fixed.
> > Thanks in advance!
> > Peter
> > Peter Tittmann
> > postgis-users mailing list postgis-users at postgis.refractions.net (mailto:postgis-users at postgis.refractions.net)
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Mit freundlichen Grüßen
> Astrid Emde
> Aufwind durch Wissen!
> Qualifizierte OpenSource-Schulungen
> bei der www.foss-academy.eu (http://www.foss-academy.eu)
> Astrid Emde
> WhereGroup GmbH & Co.KG
> Eifelstraße 7
> 53119 Bonn
> Germany
> Fon: +49(0)228 90 90 38 - 19
> Fax: +49(0)228 90 90 38 - 11
> astrid.emde at wheregroup.com (mailto:astrid.emde at wheregroup.com)
> www.wheregroup.com (http://www.wheregroup.com)
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> Amtsgericht Bonn, HRA 6788
> Komplementärin:
> WhereGroup Verwaltungs GmbH
> vertreten durch:
> Olaf Knopp, Peter Stamm
> pgp-public key:
> http://pgp.mit.edu:11371/pks/lookup?search=0x06DA52D72D515284
> Signierte und/oder verschlüsselte Nachrichten sind sehr willkommen
> Signed and/or encrypted mail is highly appreciated
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120717/dde10a86/attachment.html>
