[postgis-users] oddity with computing areas
Eric McKeeth
eldin00 at gmail.com
Tue Jul 17 16:11:49 PDT 2012
On Tue, Jul 17, 2012 at 3:48 PM, Mike Toews <mwtoews at gmail.com> wrote:
> On 18 July 2012 09:46, Mike Toews <mwtoews at gmail.com> wrote:
>> with data as (select 'POLYGON((0 0, 1 0, 1 1, 0 1, 0 0))'::geometry AS geom1,
>> 'POLYGON((0 0, 1 0, 1 1, 0 1, 0 0, 1 0, 1 1, 0 1, 0 0))'::geometry AS geom2)
>> select st_isvalid(geom1), st_area(geom1),
>> st_isvalid(geom2), st_area(geom2)
>> from data;
> Hmm, on further analysis, valid geometries shouldn't matter as much
> for ST_Intersection:
> select
> st_isvalid(st_intersection(geom1, geom1)),
> st_area(st_intersection(geom1, geom1))
> from data;
> -MIke
Ok, I found the problem and it was user error. At one point the areas
were getting treated as strings, and the string values were getting
truncated, which was losing things like 'e-007' off the end. When the
programmer fixed that, the problem went away. Sorry for the noise.
-Eric
