[postgis-users] Error compiling postgis 2.0.1 in Centos 6.3
Paul Ramsey
pramsey at opengeo.org
Wed Jul 18 13:25:51 PDT 2012
Hard to go wrong with Devrim's RPMs, fire and forget.
Your particular problem is probably caused by /usr/local/lib not being
in /etc/ld.so.conf (the library exists, but the linker isn't aware of
it until you configure that directory in)
P.
On Wed, Jul 18, 2012 at 12:59 PM, Devrim GÜNDÜZ <devrim at gunduz.org> wrote:
> On Wed, 2012-07-18 at 12:48 -0700, Nahum Castro wrote:
>> I have this error when compiling postgis 2.0.1
> <snip>
> http://yum.postgresql.org/9.1/redhat/rhel-6.3-x86_64/repoview/postgis2_91.html
> has the RPM if you want, so that you don't need to compile from sources.
> Regards,
> Devrim GÜNDÜZ
> Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
> PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
> Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
> http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
> postgis-users mailing list
