[postgis-users] Error compiling postgis 2.0.1 in Centos 6.3
Nahum Castro
pedro1_72 at yahoo.com
Wed Jul 18 19:21:58 PDT 2012
I disabled Intel TXT from the motherboard.
Now can be compiled, by the way I noticed that the system needs to be connected to the Internet to install.
postgis-out.xml:11: warning: failed to load external entity "http://www.w3.org/Math/DTD/mathml2/mathml2.dtd"
%mathml;
Entity: line 1:
%mathml;
using_postgis_dataman.xml:1372: namespace error : Namespace prefix mml on math is not defined
<mml:math display="block">
Thanks to all.
Nahum
Nahum Castro
Leon, Guanajuato, Mexico
http://www.leon-linux.com
e-mail: pedro1_72 [en] yahoo [punto] com
De: Nahum Castro <pedro1_72 at yahoo.com>
Para: Paul Ramsey <pramsey at opengeo.org>; PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Enviado: Miércoles, 18 de julio, 2012 15:44:55
Asunto: Re: [postgis-users] Error compiling postgis 2.0.1 in Centos 6.3
there is a line to /usr/local/lib in a file that i created named
/etc/ld.so.conf.d/mapas.conf
here are the out from ldconfig -v
/usr/local/lib:
libgdalconstjni.so.1 -> libgdalconstjni.so
liblwgeom-2.0.1.so -> liblwgeom.so
libosrjni.so.1 -> libosrjni.so
libNCSEcw.so.0 -> libNCSEcw.so.0.0.0
libNCSCnet.so.0 -> libNCSCnet.so.0.0.0
libjson.so.0 ->
libjson.so.0.0.1
libgdaljni.so.1 -> libgdaljni.so
libogrjni.so.1 -> libogrjni.so
libgdal.so.1 -> libgdal.so.1.16.1
libproj.so.0 -> libproj.so.0.7.0
libNCSUtil.so.0 -> libNCSUtil.so.0.0.0
libgeos-3.3.5.so -> libgeos.so
libNCSEcwC.so.0 -> libNCSEcwC.so.0.0.0
libgeos_c.so.1 -> libgeos_c.so.1.7.5
/usr/local/pgsql/lib:
libpqwalreceiver.so -> libpqwalreceiver.so
libecpg_compat.so.3 ->
libecpg_compat.so.3.3
libpgtypes.so.3 -> libpgtypes.so.3.2
libpq.so.5 -> libpq.so.5.4
libecpg.so.6 -> libecpg.so.6.3
The problem with the postgresql.org repo is that do not have gdal and raster capabilities.
I'd like to learn pgraster.
Thanks.
Nahum Castro
De: Paul Ramsey <pramsey at opengeo.org>
Para: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
CC: Nahum Castro <pedro1_72 at yahoo.com>
Enviado: Miércoles, 18 de julio, 2012 15:25:51
Hard to go wrong with Devrim's RPMs, fire and forget.
Your particular problem is probably caused by /usr/local/lib not being
in /etc/ld.so.conf (the library exists, but the linker isn't aware of
it until you configure that directory in)
P.
On Wed, Jul 18, 2012 at 12:59 PM, Devrim GÜNDÜZ <devrim at gunduz.org> wrote:
> On Wed, 2012-07-18 at 12:48 -0700, Nahum Castro wrote:
>> I have this error when compiling postgis 2.0.1
> <snip>
> http://yum.postgresql.org/9.1/redhat/rhel-6.3-x86_64/repoview/postgis2_91.html
> has the RPM if you want, so that you don't need to compile from sources.
> Regards,
> Devrim GÜNDÜZ
> Principal Systems Engineer @ EnterpriseDB: http://www.enterprisedb.com
> PostgreSQL Danışmanı/Consultant, Red Hat Certified Engineer
> Community: devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
> http://www.gunduz.org Twitter: http://twitter.com/devrimgunduz
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120718/e392fb8c/attachment.html>
