[postgis-users] Need help constructing a query
Tom van Tilburg tom.van.tilburg at gmail.com
Fri Jul 20 02:21:52 PDT 2012
Just write the 'withs' as seperate queries that create a table or make
them subqueries.
Rest is for you to figure out ;-)
P.S. I'd recommend (asking for) upgrading your postgres installation,
8.3 is getting old.....
On 20-7-2012 10:59, Pedro Doria Meunier wrote:
> Elegant :)
> Turns out I'm stuck with an old server running PG 8.3 and can't use
> WITH clause :D
> Thanks Tom!
> Pedro Doria Meunier
> Telf. +351 291 933 006
> GSM  +351 915 818 823
> Skype: pdoriam
> On 07/20/2012 09:03 AM, Tom van Tilburg wrote:
>> Hmm, I would still think that, as long as you have a single line
>> per-boat, this would solve your problem.
>> Because you can find out how often this single line crosses the bouy
>> area. The combination of ST_Intersection and ST_Dump would do that
>> for you.
>> Try something like:
>> WITH line AS
>>     SELECT
>>         gps.gps_track As boat, ST_MakeLine(gps.the_geom ORDER BY
>> gps_time) As geom
>>     FROM gps_points As gps
>>     GROUP BY gps.gps_track;
>> ,intersections AS
>>     SELECT boat, (ST_Dump(ST_Intersection(line.geom,
>> ST_SetSrid(ST_Makepoint(lon,lat),4326)))).geom
>> SELECT
>>    boat, count(boat) As number_of_passes
>>     FROM intersections
>>     WHERE ST_GeometryType(geom) = 'ST_LineString'
>>     GROUP BY boat
>> if your postgres is below 9.0 the gps.tracks might work different.
>> See manual.
>> Cheers,
>>  Tom
>> On 20-7-2012 9:38, Pedro Doria Meunier wrote:
>>> On 07/20/2012 07:38 AM, Tom van Tilburg wrote:
>>>> Hi Pedro,
>>>> You might try to create lines from the boat tracks (see examples in
>>>> manual for ST_MakeLine)  and circles (st_buffer) from the proximity
>>>> areas around the buoy.
>>>> Now do a ST_Intersection(boatline, bouycircle). The result should
>>>> be a set of lines within the bouycircle. Every line stands for one
>>>> pass along the bouy.
>>>> I think ST_Intersection might result in a geometry collection of
>>>> lines and points so you would have to make a dump of the result
>>>> with ST_Dump and then select only the lines.
>>>> Cheers,
>>>>  Tom
>>> Elegant thinking but that would end up in a *single* line, as I only
>>> have the timestamp and (point)geom to work with.
>>> Thanks for your input though :)
>>> Pedro Doria Meunier
>>> Skype: pdoriam
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120720/74ff953c/attachment.html>
