[postgis-users] Need help constructing a query
Tom van Tilburg tom.van.tilburg at gmail.com
Fri Jul 20 04:16:51 PDT 2012
Pedro, try this. No guarantee that it works on 8.3 though.
If you want this data live, make sure to use views instead of tables and
probably create a valid identifier for showing it from a mapserver.
I see one caveat by the way: if your boat passes the bouy but turns
outside your buffer and then gets into your buffer again, it will be
counted twice. Therefore make your buffer large enough.
DROP TABLE IF EXISTS lines;
CREATE TABLE lines AS
     SELECT
         gps.gps_track As boat, ST_MakeLine(gps.the_geom ORDER BY
gps_time) As geom
     FROM gps_points As gps
     GROUP BY gps.gps_track
DROP TABLE IF EXISTS intersections;
CREATE TABLE intersections AS
     SELECT boat, (ST_Dump(ST_Intersection(line.geom,
ST_SetSrid(ST_Makepoint(lon,lat),4326)))).geom
     FROM lines
DROP TABLE IF EXISTS bouy_passes;
CREATE TABLE bouy_passes As
     SELECT
    boat, count(boat) As number_of_passes
     FROM intersections
     WHERE ST_GeometryType(geom) = 'ST_LineString'
     GROUP BY boat
On 20-7-2012 13:08, Pedro Doria Meunier wrote:
> Pedro Doria Meunier
