[postgis-users] Geometry_columns of a view
manuel escobar ubreva
manuel.escobar.ubreva at gmail.com
Fri Jul 20 08:49:04 PDT 2012
Hello! I have a doubt. I created the view with geometry, with the next sql:
CREATE VIEW Z AS
SELECT a.id........, c.the_geom
FROM actgis a
JOIN Parc2009 c ON a.ref_catastral= c.refcat;
I can´t include the record into the geometry columns of generated vew. Do
you have some advices?
What can I do to renew geometry_columns with the information from the new
view?Can I use the addgeometry_columns functions or I should modify
it,because it's functiones can only be used for the table?
thanks
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120720/f27dc5a2/attachment.html>
