[postgis-users] PostGIS 1.5.5 Released
Paul Ramsey pramsey at opengeo.org
Fri Jul 20 10:30:50 PDT 2012
PostGIS 1.5.5 is a bug-fix release, which removes a bug introduced in
1.5.4 that will cause back-end crashes on spatially indexed tables
that have large numbers of null geography records.
If you are running 1.5.4 and use geography, you will want to upgrade right away.
http://postgis.org/download/postgis-1.5.5.tar.gz
 - Bug Fixes
   - #1825, containsproperly fix in prepared geometry.
   - #1832, crash when updating GIST index on geography column
   - #1865, don't strip comments COPY data from dumps on restore
