[postgis-users] SRID in geometry_columns view
Mike Toews
mwtoews at gmail.com
Tue Jul 24 15:10:45 PDT 2012
On 25 July 2012 09:49, Richard Greenwood <richard.greenwood at gmail.com> wrote:
> I am having difficulty getting my views' SRIDs into the
> geometry_columns view in PostGIS 2.0. The doc's [1] suggest casting
> the geometry in the view so I tried:
> wkb_geometry::geometry(3739)
> which generates the error:
> ERROR: Invalid geometry type modifier: 3739
Yup, this invalid, but it is not what the manual says. The typmod is
either: geometry(type,srid) or if SRID is not known, then
geometry(type), where 'type' can be one of Geometry, Point, PointZ,
etc, etc.
> next I tried:
> wkb_geometry::geometry(Geometry,3739)
> ERROR: cannot change data type of view column "wkb_geometry" from
> geometry to geometry(Geometry,3739)
You need to either assign an SRID or reproject to that SRID. Are you
geometries mixed? If not, you might want to use a more specific
geometry type, like Polygon or MultiPolygon, etc., rather than
Geometry.
To assign a missing or incorrect SRID[1]:
ALTER TABLE my_table
ALTER COLUMN wkb_geometry TYPE geometry(Geometry,3739)
USING ST_SetSRID(wkb_geometry,3739);
Or if it needs to be transformed (reprojected) to a different SRID[2]:
USING ST_Transform(wkb_geometry,3739);
-Mike
[1] http://postgis.refractions.net/docs/ST_SetSRID.html
[2] http://postgis.refractions.net/docs/ST_Transform.html
