[postgis-users] index tablespace handing in raster2psql broken
Kim Bisgaard kib at dmi.dk
Wed Jul 25 05:36:13 PDT 2012
I tried using "-X" option for raster2psql but got a PostgreSQL syntax error.
raster2psql in version 2.0.1 outputs the following SQL:
CREATE TABLE "2mt_20120802_00" ("rid" serial PRIMARY KEY,"rast" raster)
USING INDEX TABLESPACE "data"
TABLESPACE "data";
while the correct PostgreSQL 9.1 syntax is:
CREATE TABLE "2mt_20120802_00" ("rid" serial PRIMARY KEY USING INDEX TABLESPACE "data","rast" raster)
TABLESPACE "data";
where as it can be changed to use correct PostgreSQL syntax by changing code in raster/loader/raster2psql.c line 899 to:
sprintf(sql, "CREATE TABLE %s%s (\"rid\" serial PRIMARY KEY%s%s,%s raster%s)%s%s;",
(schema != NULL ? schema : ""),
table,
(idx_tablespace != NULL ? " USING INDEX TABLESPACE " : ""),
(idx_tablespace != NULL ? idx_tablespace : ""),
column,
(file_column ? ",\"filename\" text" : ""),
(tablespace != NULL ? " TABLESPACE " : ""),
(tablespace != NULL ? tablespace : "")
Furthermore is the raster2psql command installed into /usr and /usr/bin in the debian packages - I have not debugged this, so I do not know
why. It may be in "make install" or something in Ubuntu’s packages.
Thanks for the very useful SW!
Regards,
Kim Bisgaard
Application Development Division     Phone: +45 3915 7562 (direct)
Danish Meteorological Institute      Fax: +45 3915 7460 (division)
