[postgis-users] Signal 11: Segmentation fault
Rebecca Clarke
r.clarke83 at gmail.com
Wed Jul 25 06:59:24 PDT 2012
There is no index on the table.
postgis_full_version
POSTGIS="1.5.5" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.8" USE_STATS
version
PostgreSQL 9.1.4 on x86_64-unknown-linux-gnu, compiled by gcc-4.4.real
(Debian 4.4.5-8) 4.4.5, 64-bit
Until this Monday, I was using Postgresql 8.4 and postgis 1.5.1
On Wed, Jul 25, 2012 at 2:54 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Wed, Jul 25, 2012 at 02:27:14PM +0100, Rebecca Clarke wrote:
> > Your code below works for me also. It's obviously just my data.
> > the field is data type bytea:
> > \x010300000000000000
> Looks like HEXWKB to me, for "POLYGON EMPTY".
> What makes you think it is "bytea" ?
> > I ran:
> > select st_astext(the_geom) from tbl where id = 6052
> > and it returns: "POLYGON EMPTY"
> > When I run the st_isvalid on it:
> > select st_isvalid(the_geom) from tbl where id = 6052
> > or
> > select st_isvalid(the_geom::geometry) from tbl where id = 6052
> > It throws the segmentation error.
> > I just upgrade to postgis 1.5.5 and this made no difference.
> Can you show the output of "SELECT postgis_full_version()"
> _and_ the output of "SELECT version()" ?
> Is there an index on "tbl" ?
> --strk;
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120725/75acac16/attachment.html>
