[postgis-users] Signal 11: Segmentation fault
Sandro Santilli strk at keybit.net
Wed Jul 25 07:08:22 PDT 2012
On Wed, Jul 25, 2012 at 02:59:24PM +0100, Rebecca Clarke wrote:
> There is no index on the table.
Ok.
Does a round-trip (print->parse) work? :
  SELECT ST_IsValid(the_geom::text::geometry) FROM tbl where id = 6052;
Can you also show the result of:
 \d tbl
or at least the portion mentioning "the_geom"
> postgis_full_version
>  POSTGIS="1.5.5" GEOS="3.2.0-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
> 2009" LIBXML="2.7.8" USE_STATS
Uhm, it may have to do with the GEOS version, can you try upgrading that as well ?
> version
>  PostgreSQL 9.1.4 on x86_64-unknown-linux-gnu, compiled by gcc-4.4.real
> (Debian 4.4.5-8) 4.4.5, 64-bit
> Until this Monday, I was using Postgresql 8.4 and postgis  1.5.1
Are you saying your queries were working before the upgrade ?
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.1
  |  / 2.1 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
