[postgis-users] Extracting points from a line
David William Bitner
bitner at gyttja.org
Thu Jul 26 07:52:56 PDT 2012
Tom,
You've got the right toolbox out, but you're doing a bit of mismatching
between the tools.
You can certainly do this using the Linear Referencing tools by either
using ST_Add_Measure and then using ST_LocateAlong (or
ST_Locate_Along_Measure pre 2.0) OR just use ST_Line_Interpolate_Point
along with ST_Length.
Examples of how to do this in a single step:
With Measures:
SELECT
> ST_ASEWKT(ST_Locate_Along_Measure(linem,i))
> FROM
> SELECT
> ST_AddMeasure(line,0,ST_Length(line)) as linem,
>> generate_series(0,ST_Length(line)::int,25) as i
> FROM
> ST_MakeLine(ST_MakePoint(0,0),ST_MakePoint(1000,1000)) as line
> ) as foo
Without:
SELECT
ST_ASEWKT(ST_Line_Interpolate_Point(line,i/length))
FROM
SELECT
line, ST_Length(line) as length,
FROM
) as foo
On Wed, Jul 25, 2012 at 6:30 AM, Tom van Tilburg
<tom.van.tilburg at gmail.com>wrote:
> Hi Rob,
> Points in a regular interval have always been a pain to create in postgis.
> I hope someone will write a decent linear_reference code for this some time
> soon.
> Here's a way to do it:
> 1) make a line out of your points (ST_SetSrid(ST_MakeLine(pointa, pointb),
> 27700))
> 2) add an M value to your line (ST_AddMeasure(geom, start, end))
> 3) generate_series of intervals
> generate_series(0,floor(ST_Length(geom)/25.0)) < please check how to deal
> with that last segment smaller than 25 meter!
> 4) now you know how many points you need in every line you can use
> (ST_Line_Interpolate_Point(geom, (N*25)/St_Length(geom))
> when N being the numbers you got from generate series in 3).
> Make sure not to put dimensional restrictions to your tables since
> ST_AddMeasure will want to add that extra M dimension.
> Good luck!
> Tom
> On 25-7-2012 12:50, uk52rob wrote:
> Hi,
> I have two point geometry tables, with which I need to compare a single
> point from the left table to all points in the right table.
> I need to extract X and Y co-ordinates (EPSG: 27700 OSGB36/British
> National Grid) every 25m along a fictitious line between the points in
> order to build a 'profile' of the land from a database containing height
> data.
> Does anyone have any 'best practise' or experience with this sort of
> project?
> Many thanks,
> Rob
> postgis-users mailing listpostgis-users at postgis.refractions.nethttp://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120726/14bab219/attachment.html>
