[postgis-users] Extracting points from a line
Tom van Tilburg
tom.van.tilburg at gmail.com
Fri Jul 27 08:04:12 PDT 2012
David, I should read before I write... completely missed this in the new
postgis version.
I was basing myself on a post from opengeo where it is still in a roadmap:
http://opengeo.org/technology/postgis/coredevelopment/lrs/
Again, thanks for pointing me out. Really happy to see this!
Cheers,
Tom
On 27-7-2012 16:24, David William Bitner wrote:
> What kind of upgrades are you after? ST_LocateAlong does allow for
> offsetting along a line.
> On Fri, Jul 27, 2012 at 3:16 AM, Tom van Tilburg
> <tom.van.tilburg at gmail.com <mailto:tom.van.tilburg at gmail.com>> wrote:
> Thanks for pointing that out David!
> I got my example from an existing piece of code that needed
> measures later on, so at that time it made sense to create the
> measure.
> Nevertheless I'm hoping for some upgrade of the linear referencing
> functions. Especially the option of offsetting along a line would
> be superb.
> On 26-7-2012 16:52, David William Bitner wrote:
>> Tom,
>> You've got the right toolbox out, but you're doing a bit of
>> mismatching between the tools.
>> You can certainly do this using the Linear Referencing tools by
>> either using ST_Add_Measure and then using ST_LocateAlong (or
>> ST_Locate_Along_Measure pre 2.0) OR just use
>> ST_Line_Interpolate_Point along with ST_Length.
>> Examples of how to do this in a single step:
>> With Measures:
>> _____________________________________________
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120727/977e3f6d/attachment.html>
