[postgis-users] Intersection of LineStrings
Ed Linde
edolinde at gmail.com
Wed Jun 6 08:10:47 PDT 2012
Hi Steve,
What indexes can I put on the linestring column? Is there an option of
using a R-Tree index?
Thanks,
Ed
On Wed, Jun 6, 2012 at 4:54 PM, Stephen Woodbridge
<woodbri at swoodbridge.com>wrote:
> On 6/6/2012 9:57 AM, Ed Linde wrote:
>> Hi All,
>> Simple question. I have a table with half a million linestring
>> geometries, and I want to compute the
>> intersection points and also the linestring pairs that intersect with
>> each other.
>> How can I do this? Is there an index that can avoid having to do a
>> self-join and computing
>> the intersections?
> Create a spatial index on your table of linestrings and do a self join
> select a.gid, b.gid, st_intersection(a.the_geom, b.the_geom)
> from linestrings a, linestrings b
> where a.the_geom && b.the_geom and st_intersects(a.the_geom, b.the_geom);
> You might get away with using this instead for the where:
> where st_dwithin(a.the_geom, b.the_geom, 0.0);
> Which might be faster.
> The result will potentially be a collection if there is more then one
> intersection and/or might be a linestring if the intersection is an overlap
> along some part of the two strings.
> -Steve
> ______________________________**_________________
> postgis-users mailing list
> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120606/b9811db4/attachment.html>
