[postgis-users] Error adding raster support
Nordgren, Bryce L -FS bnordgren at fs.fed.us
Wed Jun 6 11:16:24 PDT 2012
> -----Original Message-----
> But I'm getting the following error:
> psql:/usr/share/postgresql/9.1/contrib/postgis-2.0/rtpostgis.sql:70: ERROR:
> could not load library "/usr/lib/postgresql/9.1/lib/rtpostgis-2.0.so":
> libgdal.so.1: cannot open shared object file: No such file or directory
Do you have gdal installed?
This electronic message contains information generated by the USDA solely for the intended recipients. Any unauthorized interception of this message or the use or disclosure of the information it contains may violate the law and subject the violator to civil or criminal penalties. If you believe you have received this message in error, please notify the sender and delete the email immediately.
