[postgis-users] Error adding raster support
Bborie Park
bkpark at ucdavis.edu
Thu Jun 7 08:35:31 PDT 2012
Luis,
PostGIS 2.0 does support GDAL 1.6. I'm expecting that the GDAL 1.6
coming from the repos uses the naming convention libgdal16.so.1
instead of the default libgdal.so.1, which is known to cause problems.
Were you compiling PostGIS 2.0 or using a package from a repo?
-bborie
On Thu, Jun 7, 2012 at 4:36 AM, Luis <luis.a.de.sousa at gmail.com> wrote:
> Thank you all for the replies.
> Initially I tried to install GDAL from the repos, which for Ubuntu 10.04 is
> only available in version 1.6.0. But contrary to what the readme files says
> PostGis 2 doesn't go with this version of GDAL. So I download and compiled
> GDAL 1.9.1, hence I doubt it is an issue.
> Any other insights would be very welcome.
> Thank you.
> View this message in context: http://postgis.17.n6.nabble.com/Error-adding-raster-support-tp4998034p4998070.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
