[postgis-users] gdalinfo gives no georeferencing information for a PostGIS raster
Bborie Park bkpark at ucdavis.edu
Fri Jun 8 07:43:43 PDT 2012
Robin,
The output you're seeing is as expected.  When calling gdalinfo with
no "mode" setting, I believe the mode is defaulted to "mode=1".
According to the docs...
"mode = 1. Also called ONE_RASTER_PER_ROW mode. In this case, a raster
table is considered as a bunch of different raster files. This mode is
intended for raster tables storing different raster files. It's the
default mode if you don't provide this field in connection string. "
Basically, this one treats the table as a dataset and each row within
as a subdataset.  Subdatasets can be substantially different from the
container dataset.  The output you're seeing is for the dataset.
What you're looking for (and probably were expecting) was mode = 2.
"mode = 2. Also called ONE_RASTER_PER_TABLE mode. In this case, a
raster table is considered as a unique raster file, even if the table
has more than one row. This mode is intended for reading tiled rasters
from database. "
Here, you should see what you expect to see.  So for your call to gdalinfo...
dalinfo  "PG:host=localhost port=5432 dbname='testgis'
     user='postgres' password='' schema='ch13' table=kauai mode=2"
-bborie
On Fri, Jun 8, 2012 at 4:21 AM, Robin Wilson <robin at rtwilson.com> wrote:
> Hi,
> I'm fairly new to PostGIS (version 2) and I'm struggling with a problem
> where gdalinfo doesn't seem to give the correct georeferencing information
> for a raster in PostGIS. I've asked a StackOverflow question about it, and I
> wondered if anyone here may be able to help - either on this mailing list or
> on the SO question?
> http://gis.stackexchange.com/questions/26958/gdalinfo-gives-no-georeferencing-information-for-a-postgis-raster#comment36245_26958
> Best regards,
> Robin
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
