[postgis-users] RE : 3D polyline simplify
Francois Hugues hugues.francois at irstea.fr
Sun Jun 17 13:01:29 PDT 2012
I don't understand what is a 3D polyline.
Your 3D points have x, y coordinates and a z value. If you make your polyline from a selection of points in a raster DEM, you will just have a polyline representing something from the 3D. With st_simplifiy, you will symplify this representation.
Instead your polyline is a multiline, I think you can use st_simplify instead of st_simplifypreservetopology.
Hugues.
-------- Message d'origine--------
De: postgis-users-bounces at postgis.refractions.net de la part de Ed Linde
Date: dim. 17/06/2012 11:30
À: PostGIS Users Discussion
Objet : [postgis-users] 3D polyline simplify
Does *ST_SimplifyPreserveTopology : *work with a 3D polyline as well? So if
I had a linestring which I composed from several
3D points using ST_MakeLine, would the DP algorithm still work?
Cheers,
Ed*
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120617/49b7deba/attachment.bin>
