[postgis-users] Create topologic layers from simple geometries
Mike Toews
mwtoews at gmail.com
Wed Jun 20 14:19:40 PDT 2012
Hi Laurent,
I recommend renaming your "Land_cover" table to "land_cover" (with a
lower case "l"). It is pretty easy to do with pgAdminIII. Renaming
your table to lower case will make your queries simpler, since you
won't need to use double quotes.
Read more about your situation here:
http://momjian.us/main/blogs/pgblog/2012.html#June_12_2012
-Mike
