[postgis-users] Finding highest cell value in raster using ST_Value
e.j.h.polle
e.j.h.polle at gmail.com
Sun Jun 24 07:24:58 PDT 2012
Hi Group,
I think I want your opinion on a query I have written.
The goal is to find the highest value in a DEM, a raster table. The
solution I found brings me where I want to go, but it takes 45 seconds on a
relatively small (225*259) grid. It looks like it is especially the nested
loop on the ST_Value function in the subquery that does take some time.
Can you have a look at the query below and tell me if I am on the right
track. Or is there an other route I should follow?
A full description of my workflow (and the origin of the table used) can be
found in 2 blog posts:
http://twiav-tt.blogspot.nl/2012/06/postgis-raster-analysis-find-highest.html
http://twiav-tt.blogspot.nl/2012/06/postgis-raster-analysis-find-highest_24.html
This is the query:
INSERT INTO france.highest_peak_martinique(height, geom)
SELECT height, ST_SetSRID(ST_MakePoint(ST_Raster2WorldCoordX(rast,x),
ST_Raster2WorldCoordY(rast,y)),32620) as geom FROM
(SELECT ST_Value(rast, hor.n, ver.n) AS height, hor.n AS x, ver.n AS y
FROM generate_series(1,225) as hor(n), generate_series(1,259) as ver(n),
france.mnt_martinique
ORDER BY height DESC LIMIT 1) AS highest_cell_value, france.mnt_martinique;
Please let me know what you think.
TIA,
Egge-Jan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120624/02e3d817/attachment.html>
