[postgis-users] Selecting pairs of points that have the samedistance between them
Francois Hugues
hugues.francois at irstea.fr
Mon Jun 25 02:26:50 PDT 2012
Hello,
I may be wrong but I don't see any answer to your question. Below is a request which could do the job you need if I understood it well :
Hugues
PS : as you can see Nicolas, I learnt from your mail and I'm now able to create a "serial" column into a request ;)
create temp sequence myseq increment by 1 Minvalue 1;
with mydist as (
select nextval('myseq') new_id, a.id id1, b.id id2, st_distance(a.geom, b.geom) dist from my table_of_points a, my table_of_points b
where a.id < b.id
select a.new_id n_id1, b.new_id n_id2, id1, id2 from mydist
where a.new_id < b.new_id
and a.dist = b.dist
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Bob Pawley
Envoyé : dimanche 24 juin 2012 20:16
À : postgis-users at postgis.refractions.net
Objet : [postgis-users] Selecting pairs of points that have the samedistance between them
Hi
I have a geometry of points (more than one pair) that represent the intersections between a line and a column of multistrings.
Can anyone point me to a method of determining which pairs of points are the same distance apart as are other pairs of points.
This will isolate the closed object from the open object for me.
The srid is all -1.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120625/597f67a6/attachment.html>
