[postgis-users] Problem compiling PostGIS2.0 with GEOS 1.3.3+
Jan Hartmann j.l.h.hartmann at uva.nl
Mon Jun 25 04:07:08 PDT 2012
On 06/25/2012 11:32 AM, Sandro Santilli wrote:
> Autotools do something like this:
> DEFAULT_INCLUDES = -I. -I$(top_builddir)/include -I$(top_builddir)/include/geos
> CXXCOMPILE = $(CXX) $(DEFS) $(DEFAULT_INCLUDES) $(INCLUDES) \
>          $(AM_CPPFLAGS) $(CPPFLAGS) $(AM_CXXFLAGS) $(CXXFLAGS)
> Where DEFAULT_INCLUDES is automatically generated and $(CPPFLAGS)
> and $(CXXFLAGS) are the ones you eventually override.
> In PostGIS we don't have this double definition so it won't work:
>          $(LIBTOOL) --mode=compile $(CC) $(CFLAGS) -c -o $@ $<
> I guess we could add a $(DEFAULT_INCLUDES) right before the CFLAGS.
> Then you could use:
>   make CFLAGS=...
> Note that "CFLAGS=... make" has no effect on either PostGIS or GEOS
> (autotools-based) for me.
No, it is a configure problem. Sorry, I didn't explain it right. The
command is "CFLAGS=... LDFLAGS=...  configure".  After that, all
following "makes" include those paths before all system generated paths.
The problem arises when in an earlier path there is an older version of
a library or header file. I don't see a simple solution.
Jan
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120625/de534960/attachment.html>
