[postgis-users] Error adding raster support
Bborie Park bkpark at ucdavis.edu
Mon Jun 25 08:28:47 PDT 2012
Hey Luis,
What happens when you run "gdalinfo" or "gdal_translate" without any
parameters?  I'm expecting an error message indicating that GDAL can't
find some library.
I'm guessing that the GDAL library can't find the libraries it was
compiled against.  If you run "ldd" on libgdal.so.1 and still get the
"not found" messages, you'll want to check your GDAL build.
-bborie
On Mon, Jun 25, 2012 at 12:38 AM, Luis <luis.a.de.sousa at gmail.com> wrote:
> Hi Bborie, here it is:
> $ ldd /home/weastflows/temp/postgis-2.0.0/raster/rt_pg/rtpostgis-2.0.so
>        linux-vdso.so.1 =>  (0x00007fffb8c98000)
>        libgdal.so.1 => /usr/local/lib/libgdal.so.1 (0x00007fde9a573000)
>        libgeos_c.so.1 => /usr/local/lib/libgeos_c.so.1 (0x00007fde9a34e000)
>        libc.so.6 => /lib/libc.so.6 (0x00007fde99fca000)
>        libgeos-3.3.4.so => /usr/local/lib/libgeos-3.3.4.so (0x00007fde99c29000)
>        libsqlite3.so.0 => /usr/lib/libsqlite3.so.0 (0x00007fde9999c000)
>        libodbc.so.1 => not found
>        libodbcinst.so.1 => not found
>        libxerces-c.so.28 => not found
>        libjasper.so.1 => not found
>        libnetcdf.so.4 => not found
>        libhdf5.so.6 => not found
>        libmfhdfalt.so.0 => not found
>        libdfalt.so.0 => not found
>        libgif.so.4 => not found
>        libjpeg.so.62 => not found
>        libpng12.so.0 => /lib/libpng12.so.0 (0x00007fde99771000)
>        libpq.so.5 => /usr/lib/libpq.so.5 (0x00007fde99544000)
>        libz.so.1 => /lib/libz.so.1 (0x00007fde9932c000)
>        libpthread.so.0 => /lib/libpthread.so.0 (0x00007fde9910f000)
>        librt.so.1 => /lib/librt.so.1 (0x00007fde98f07000)
>        libdl.so.2 => /lib/libdl.so.2 (0x00007fde98d02000)
>        libcurl-gnutls.so.4 => /usr/lib/libcurl-gnutls.so.4 (0x00007fde98abf000)
>        libstdc++.so.6 => /usr/lib/libstdc++.so.6 (0x00007fde987ab000)
>        libm.so.6 => /lib/libm.so.6 (0x00007fde98527000)
>        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00007fde98310000)
>        /lib64/ld-linux-x86-64.so.2 (0x00007fde9b549000)
>        libssl.so.0.9.8 => /lib/libssl.so.0.9.8 (0x00007fde980bd000)
>        libcrypto.so.0.9.8 => /lib/libcrypto.so.0.9.8 (0x00007fde97d2c000)
>        libkrb5.so.3 => /usr/lib/libkrb5.so.3 (0x00007fde97a68000)
>        libcom_err.so.2 => /lib/libcom_err.so.2 (0x00007fde97863000)
>        libgssapi_krb5.so.2 => /usr/lib/libgssapi_krb5.so.2 (0x00007fde9762f000)
>        libldap_r-2.4.so.2 => /usr/lib/libldap_r-2.4.so.2 (0x00007fde973e3000)
>        libidn.so.11 => /usr/lib/libidn.so.11 (0x00007fde971af000)
>        liblber-2.4.so.2 => /usr/lib/liblber-2.4.so.2 (0x00007fde96fa1000)
>        libgnutls.so.26 => /usr/lib/libgnutls.so.26 (0x00007fde96cff000)
>        libgcrypt.so.11 => /lib/libgcrypt.so.11 (0x00007fde96a86000)
>        libk5crypto.so.3 => /usr/lib/libk5crypto.so.3 (0x00007fde96860000)
>        libkrb5support.so.0 => /usr/lib/libkrb5support.so.0 (0x00007fde96657000)
>        libkeyutils.so.1 => /lib/libkeyutils.so.1 (0x00007fde96454000)
>        libresolv.so.2 => /lib/libresolv.so.2 (0x00007fde9623b000)
>        libsasl2.so.2 => /usr/lib/libsasl2.so.2 (0x00007fde96020000)
>        libtasn1.so.3 => /usr/lib/libtasn1.so.3 (0x00007fde95e0f000)
>        libgpg-error.so.0 => /lib/libgpg-error.so.0 (0x00007fde95c0b000)
> Thanks for answering.
> View this message in context: http://postgis.17.n6.nabble.com/Error-adding-raster-support-tp4998034p4998559.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
