[postgis-users] proj4 error between versions 8.4.2 (works) and 9.1.4 (doesn't work)
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Tue Jun 26 07:52:51 PDT 2012
Sorry, forgot to add the error:
ERROR: AddToPROJ4SRSCache: couldn't parse proj4 string: '+proj=lcc +lat_2=44.88333333333333 +lat_1=45.13333333333333 +lat_0=44.79111111111111 +lon_0=-93.38333333333334 +x_0=152400.3048 +y_0=30480.0610 +units=ft +to_meter=0.30480060960122 +a=6378418.941 +b=6357033.310 +no_defs': projection not named
********** Error **********
SQL state: XX000
From: postgis-users-bounces at postgis.refractions.net [postgis-users-bounces at postgis.refractions.net] on behalf of Basques, Bob (CI-StPaul) [bob.basques at ci.stpaul.mn.us]
Sent: Tuesday, June 26, 2012 9:51 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] proj4 error between versions 8.4.2 (works) and 9.1.4 (doesn't work)
I'm getting an error in proj4text in 9.1.4 for our custom projection which works just fine in 8.4.2.
when inserting a geom like:
INSERT INTO InsertInfoStp(. . . .
the_geom,
VALUES (. . . .
ST_Transform (ST_SetSRID (ST_MakePoint (-93.1286,44.9675), 4326), 200068),
The problem is in the ST_Transform, if I drop it, it succeeds.
Can anyone see anything obvious with :
srid=200068
auth_name=EPSG
auth_srid=200068
srtext=PROJCS["MN Ramsey County",GEOGCS["NAD83 (1986)",DATUM["GRS 1980 + MN Ramsey Elevation",SPHEROID["Unknown",6378418.941,298.2572242549219]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]], PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["standard_parallel_1",45.13333333333333],PARAMETER["standard_parallel_2",44.88333333333333],PARAMETER["latitude_of_origin",44.79111111111111], PARAMETER["central_meridian",-93.38333333333334],PARAMETER["false_easting",500000],PARAMETER["false_northing",100000],UNIT["Foot_US",0.30480060960121924]]
proj4text=+proj=lcc +lat_2=44.88333333333333 +lat_1=45.13333333333333 +lat_0=44.79111111111111 +lon_0=-93.38333333333334 +x_0=152400.3048 +y_0=30480.0610 +units=ft +to_meter=0.30480060960122 +a=6378418.941 +b=6357033.310 +no_defs
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120626/c338b6c8/attachment.html>
