[postgis-users] Unable to add the postgis 2.0 shapefile loader plug-in to postgres 8.4.12
Melpati, Muni Muni.Melpati at dot.state.fl.us
Thu Jun 28 09:28:59 PDT 2012
Problem solved. I was only looking at plugins in wrong location. Thanks.
Sent: Thursday, June 28, 2012 11:06 AM
To: 'postgis-users at postgis.refractions.net'
Subject: Unable to add the postgis 2.0 shapefile loader plug-in to postgres 8.4.12
I have installed postgis 2.0 over Postgres 8.4.12. However, I could not see the postgis shapefile loader plugin in the pgadmin III plugins. However, I can see it from the start menu.
I checked the plugins.ini. It is consistent with what described at http://www.postgresonline.com/journal/archives/145-PgAdmin-III-Plug-in-Registration-PostGIS-Shapefile-and-DBF-Loader.html.  For my installation "postgisgui\shp2pgsql-gui.exe" is actually located at "D:\PostgreSQL\8.4\bin" and PG bin path is rightfully specified at "D:\PostgreSQL\8.4\bin". Is there anything that would have gone wrong? Thanks.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120628/e08db879/attachment.html>
