[postgis-users] SRTM Raster Geometry question
yvecai
yvecai at gmail.com
Sun Mar 4 11:30:51 PST 2012
It seems to me that the SRTM dataset is available in tiles of 1°x1°,
with a 3 arc second resolution, which gives a raster of 1200x 1200
pixels. 3 arc second is ~90 meter, but *exactly* 3 arc second in WGS84.
http://dds.cr.usgs.gov/srtm/version2_1/Documentation/Quickstart.pdf
Yves
Le 04/03/2012 19:36, Ed Linde a écrit :
> Yves, I am not sure I understand what you are saying..sorry. My
> question is basically if the points within a single cell can
> potentially have different elevation values because of interpolation?
> Or do all the points that lie within a cell get one elevation
> value?
> On Sun, Mar 4, 2012 at 2:36 PM, yvecai <yvecai at gmail.com
> <mailto:yvecai at gmail.com>> wrote:
> Le 04/03/2012 14:14, Ed Linde a écrit :
>> Hi All,
>> Can someone help me understand a concept with the SRTM raster. My
>> understanding is that the raster can be thought of as a uniform
>> grid with each cell having dimension = "90m x 90m" (for SRTM-1
>> dataset). Now I am just wondering if the elevation values are 4
>> values at each vertex or boundary point of a cell? or is it one
>> elevation value for the 90x90 m^2 area covered by the cell? I ask
>> because if its the first option, then it would mean that every
>> point that falls in the cell has it's elevation calculated using
>> some sort of interpolation between the 4 corner points of the
>> cell to arrive at this point's altitude. Or do several points
>> that fall into this 90x90 cell get assigned the same elevation value?
>> Would be great if I could get some help understanding this
>> concept about SRTM rasters.
>> Cheers,
>> Ed
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Wouldn't that be a grid of 1°/1201 by 1°/1201 with 1201x1201
> elevation value?
> Just a guess.
> Yves
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120304/42d28f2b/attachment.html>
