[postgis-users] Slow delete of duplicate rows
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Mar 5 08:17:08 PST 2012
On 3/5/2012 11:12 AM, DrYSG wrote:
> I have a large table (20M records) but mostly short text fields. There are
> duplicates that I am trying to remove. I have a bigseriel index that I
> unique, but duplicates in another field.
> I have an 8 core, 24GB memory computer with RAID disks.
> This request has been running for 70 hours (is it safe to kill it?).
Yes, it is safe.
> How can I make this run faster? This is a one time processing task, but it
> is taking a long time.
CREATE TABLE portal.new_metatdata AS
select distinct on (data_object.unique_id) * FROM portal.metadata;
Or something of this ilk should be faster because it only need to do a
sort on data_object.unique_id and then an insert. After you have
verified the results you can do:
BEGIN;
ALTER TABLE portal.metatdata rename TO portal.new_metatdata_old;
ALTER TABLE portal.new_metatdata rename TO portal.metatdata_old;
COMMIT;
Other people might have other ideas.
-Steve
> DELETE FROM portal.metadata
> WHERE idx NOT IN
> SELECT MIN(idx)
> GROUP BY "data_object.unique_id"
> CREATE TABLE
> metadata
> data_object.unique_id CHARACTER(64) NOT NULL,
> size_bytes BIGINT,
> object_date TIMESTAMP(6) WITHOUT TIME ZONE,
> object_type CHARACTER VARYING(25),
> classification CHARACTER VARYING(7),
> object_source CHARACTER VARYING(50),
> object_managed_date TIMESTAMP(6) WITHOUT TIME ZONE,
> clevel INTEGER,
> fsctlh CHARACTER VARYING(50),
> oname CHARACTER VARYING(40),
> description CHARACTER VARYING(80),
> horizontal_datum CHARACTER VARYING(20),
> do_location CHARACTER VARYING(200),
> elevation_ft INTEGER,
> location USER-DEFINED,
> idx BIGINT DEFAULT nextval('portal.metadata_idx_seq'::regclass) NOT
> NULL,
> bbox CHARACTER VARYING(160),
> CONSTRAINT MetaDataKey PRIMARY KEY (idx)
> View this message in context: http://postgis.17.n6.nabble.com/Slow-delete-of-duplicate-rows-tp4548251p4548251.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
