[postgis-users] Spatial column from text via a VIEW, Possible?
Bob Basques Bob.Basques at ci.stpaul.mn.us
Tue Mar 6 11:25:47 PST 2012
All,
I hit this earlier in my testing, so I must have had things in the right order at some earlier point in the process.
This :
select
           ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326) as geom,
           ST_AsText(ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326)) as geom_text,
           ST_AsText(ST_Transform(ST_SetSRID(ST_MakePoint(part3::numeric, part4::numeric),4326), 200068)) as geom_city
      from
          (select rxtime,
                  split_part(cmd, ',', 3) as part3,
                  split_part(cmd, ',', 4) as part4
             from
                  cmdstpinfo
            where cmd
             like '>Plot:%') AS first_pass;
is producing this (which I did hit early on but thought I had the syntax wrong at the time) :
ERROR:  transform: couldn't project point (44.9677 -93.1268 0): latitude or longitude exceeded limits (-14)
********** Error **********
SQL state: XX000
This indicates to me that the transform stuff is there , but that it failed.  I haven't found many references to this error online.  The numbers above are the numbers from the first record in the table.  When I hit this earlier, I thought I might be trying to transform against the TEXT (those numbers) object vs the GEOM object (which I'm supposed to use, right??).  The result of the ST_SetSRID seems to be the correct type of object to pass to ST_Transform based on what I found in my searches.  Maybe I'm not supposed to try the transform in this manner.
bobb
>>> Mike Toews <mwtoews at gmail.com> wrote:
> part4::numeric),4326)), 200068) as geom_city
> ERROR:  function st_transform(geometry) does not exist
> LINE 4:            ST_AsText(ST_Transform(ST_SetSRID(ST_MakePoint(pa...
It looks like "4326)), 200068)" should be "4326), 200068))"
-Mike
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120306/212128a9/attachment.html>
